Question regarding changing my oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phluffhead93, Feb 18, 2019.
  1. Feb 18, 2019 at 8:41 AM
    Phluffhead93
    Phluffhead93 [OP] Active Member
    Grand Rapids, MI
    2009 TRD Sport - DCLB - 4X4
    It's time for an oil change and I figured this would be a good time to learn how to do it myself. After draining the old oil, a lot of videos say I need a torque wrench to ensure I don't over or under tighten the drain plug. Is that necessary? If I confirm the drain plug washer is in good shape, can I just tighten it using my best judgement? I don't want to mess anything up, but I also don't want to spend unnecessary money/time on something I don't need. Any help is appreciated.
  2. Feb 18, 2019 at 8:43 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Just tighten it up snug, and don't go crazy with the power arms. You will be fine.
  3. Feb 18, 2019 at 8:44 AM
    Phluffhead93
    Grand Rapids, MI
    Thanks. I figured this wasn't 100% necessary.
    MattCowsmasher and Mully[QUOTED] like this.
  4. Feb 18, 2019 at 8:45 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
  5. Feb 18, 2019 at 8:46 AM
    squeaky
    squeaky Well-Known Member
    Wisconsin
    2014 MGM DCSB Sport 4x4
    This. However, I’d recommend picking up a bag of the oem washers off Amazon. Very cheap and good insurance.
  6. Feb 18, 2019 at 8:53 AM
    Phluffhead93
    Grand Rapids, MI
    Any links to true OEM washers? Most reviews on Amazon products say they're not actually Toyota made.
    TRDPro916 and MattCowsmasher like this.
  7. Feb 18, 2019 at 9:01 AM
    Tempest151
    Tempest151 Well-Known Member
    Joseph
    Fresno CA
    2006 Tacoma 2.7 4x4
    6” procomp. Large coil springs. Cold air. Port and polished head and throttle body. Exhaust. Positraction. Shaved and reinforced tailgate. Camper shell. Piaa fog. 5% tint all around. Stereo 2-12” 2-6x9” 2- 5 1/4” 4400 Watts 20 ferrets. Much more
    On tightening just use your “poor man torque wrench”
    The longer the wrench/ratchet with your hand further out the tighter it will be. For example a 1/2 drive long breaker bar.
    The shorter the wrench/ratchet with your hand in closer= Lower torque amount. For example a 1/4 ratchet.
    Leverage plays a big factor. Overtighening can be just as bad as under.
  8. Feb 18, 2019 at 9:06 AM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Just make sure to drain the oil from the correct pan. Too many have drained their transmission oil by mistake.
    Also, I recommend tightening the drain bolt by hand first before using the wrench to avoid cross threading.
  9. Feb 18, 2019 at 9:07 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Yea you don’t even need a hose with this thing. One the large oil containers from autozone ( these guys https://m.autozone.com/shop-and-gar...otool-12-qt-dispos-oil-recycle-can/786699_0_0) works great on 4x4s. My truck has one size up tires and this container fits under the valve perfect...no spillage.
  10. Feb 18, 2019 at 9:09 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    rmorse[QUOTED] likes this.
  11. Feb 18, 2019 at 9:15 AM
    Phluffhead93
    Grand Rapids, MI
    Also, what size hose do I need to attach to the bottom of the oil filter for when I remove that?
    MattCowsmasher likes this.
  12. Feb 18, 2019 at 9:19 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I use a Dixie cup with some tape on it to loop around the filter housing.
  13. Feb 18, 2019 at 9:22 AM
    rmorse
    Bobby
    Bowie, MD
    Oh I have a pavement princess so no skids for me haha
  14. Feb 18, 2019 at 9:22 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I use a water or soda bottle. Just hold while it drains, wipe the filter part with a rag and pour oil in to my oil bucket. You can buy a torque wrench at Harbor Freight tools for $15-20 !!!
  15. Feb 18, 2019 at 9:23 AM
    rmorse
    Bobby
    Bowie, MD
    I would trust German torque over a $20 harbor freight torque wrench.
    It’s an oil plug. Go until it’s tight, and then do 1/4-1/2 turn more
    Skyway likes this.
  16. Feb 18, 2019 at 9:25 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Heck ya brotha, life of ease sounds enticing for next truck. This one will be my dedicatied play rig at some point.
  17. Feb 18, 2019 at 9:52 AM
    squeaky
    Wisconsin
  18. Feb 18, 2019 at 11:33 AM
    Phluffhead93
    Grand Rapids, MI
    At about the 2:00 minute mark in this video it shows them removing the rubber plug before attaching the hose onto the filter before removing it. It's the only video I can find where they do that. Why does this video show them doing that, and why do other videos skip this step?
    https://www.youtube.com/watch?v=T-dbpL9w2SM
    Thanks for all the help so far!
  19. Feb 18, 2019 at 12:22 PM
    rmorse
    Bobby
    Bowie, MD
    Because tacos came with that plug from the factory and they last one oil change before they get thrown away or lost. Don’t worry about it...you probably don’t have one anymore
  20. Feb 18, 2019 at 12:24 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I have never used a torque wrench to tighten my oil drain bolt. I thread it carefully and use common sense.
    Tacotim0321 likes this.
