Question regarding changing my oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phluffhead93, Feb 18, 2019.
  1. Feb 19, 2019 at 7:29 AM
    #41
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Do you know the purpose of a crush washer? Serious question. If you understood what a crush washer is and why you use one and what happens when you torque it down, you would not be saying you can reuse them. Stop spreading misinformation that can hurt members vehicles.
    69 Jim likes this.
  2. Feb 19, 2019 at 9:23 AM
    #42
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    desertrunner24 likes this.
  3. Feb 19, 2019 at 9:43 AM
    #43
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    You will find out that the older you get, the harder it is to get a good nights sleep. Change the washer, don't add worry to the sleep problem. It's a little money for a lot of piece of mind. I had a plug leak from a dealer oil change, that pain in the ass ordeal was worth a life time supply of crush washers.
    PzTank likes this.
  4. Feb 19, 2019 at 10:08 AM
    #44
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Plastic crush washers- I’ve always replaced if removed.
    Copper- I used to heat them up til glowing red to anneal them. That usually softened them enough to safely reuse. Now-a-days, I only do that if the new one doesn’t fit, or if I don’t have another on hand in my assortment kit.
  5. Feb 19, 2019 at 10:14 AM
    #45
    rmorse
    Bobby
    Bowie, MD
    We all know he wasn’t talking about annealing copper washers before reusing them
  6. Feb 19, 2019 at 10:14 AM
    #46
    TacoRonin
    TacoRonin Member
    2009 Tacoma TRD Off-RD Pgk 2WD PreRunner
    Brush Guard, Mobtown Tailgate Plate, LED Light(s), K&N Air Filter,
    As many mentioned, just a nice snug touch will be fine. I tend to use the washers over a couple of oil changes. No issues as I'm not "truly" crushing the washer. And I just use an empty water bottle to catch any drainage oil from the filter, works fine. Just dump that into the container and take to Autozone to dump.
    Tarheel22 and b_r_o like this.
  7. Feb 19, 2019 at 3:12 PM
    #47
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
    Has anyone experienced a Fumoto drain valve failing? Any leaks or failures? Thanks
  8. Feb 19, 2019 at 5:47 PM
    #48
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've used Teflon tape on my drain plugs for years with no problems. I also like the slight interference fit it provides. I just do a good snug on my re-install and figure even if it was a little on the loose side, the Teflon tape would keep if from vibrating or thermal cycling out.
    I use it on my diff drain and fill plugs as well. I believe it keeps them from seizing into place.
    b_r_o likes this.
  9. Feb 19, 2019 at 6:10 PM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Permatex makes a paste that is basically the liquid version of teflon tape. You brush it on like ant-seize, works really good
    https://www.amazon.com/Permatex-806...a-569800664083&psc=1&ref=&adgrpid=61941536837
  10. Feb 19, 2019 at 6:20 PM
    #50
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    What get's me is the idea of trying to save a few cents on a crush washer when it's attached to a multi thousand dollar vehicle. SMH. Won't ever get it.
  11. Feb 20, 2019 at 6:08 AM
    #51
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Toyota part #90430-12031 - available on ebay most of the time for about .40 cents ea. - free delivery. My truck gets a new one each and every time.
    The copper washer that at least one person in this discussion seems to believe will last forever, may do just that, but that washer is not part # 90430-12031. The copper washer used on my '95 Isuzu Rodeo 3.2L V6 was changed maybe twice in 300K miles, but it was a real copper washer - nice and thick. Toyota part # 90430-12031 is much thinner.
    #51
  12. Feb 20, 2019 at 6:58 AM
    #52
    96carboard
    96carboard Well-Known Member
    Apparently I know better than you do.
  13. Feb 20, 2019 at 7:01 AM
    #53
    96carboard
    Even if you leave it off entirely, what exactly do you think will happen? I'll tell you: you *might* get a few drips of oil on your driveway, and it *might* be extra hard to remove at the next oil change.
    jproffer likes this.
  14. Feb 20, 2019 at 7:03 AM
    #54
    rmorse
    Bobby
    Bowie, MD
    You don’t, if you think crush washers are reusable. Stop spreading misinformation that can damage people’s vehicles.
    scocar and TacomaSport86 like this.
  15. Feb 20, 2019 at 7:09 AM
    #55
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    #55
  16. Feb 20, 2019 at 7:17 AM
    #56
    96carboard
    Plastic? o_O
    I've never heard of such a thing.
    In this case, throw it out and buy a real copper washer. I wouldn't trust plastic even to use just once.
  17. Feb 20, 2019 at 7:40 AM
    #57
    rmorse
    Bobby
    Bowie, MD
    Your ignorance is, again, showing.
    EdgeCrusher and b_r_o like this.
  18. Feb 20, 2019 at 10:45 AM
    #58
    Lester Lugnut
    Google -> plastic drain plug washer.
    May actually be nylon in some cases, but they've been around a long time. I used a generic version sold at one of the mass marketers back when I had an '87 Accord. They worked well, but were definitely a one-use gasket.
    b_r_o likes this.
  19. Feb 20, 2019 at 11:44 AM
    #59
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    You guys are over doing it. No thread sealant, no fumoto (they are garbage, used to be good), get a toyota washer, they are cheap usually come with the toyota
    filters. Use a Toyota filter. Buy a carton. Buy a good oil. No dino's. The oil change on these trucks is stupidly simple.
    Noslackline, Norton and b_r_o like this.
  20. Feb 20, 2019 at 12:04 PM
    #60
    rmorse
    Bobby
    Bowie, MD
    My fumoto is 4 years old and very high quality. The best part about it is no worries about burning your hand. You can have the oil boiling hot and flip the valve, which helps to get the most oil drained
    b_r_o likes this.
