Question Regarding UCA's
Discussion in 'Suspension' started by Silva, Jun 26, 2010.
  1. Jun 26, 2010 at 12:53 AM
    Silva
    Silva [OP] Member
    Maryland
    I recently installed a pro comp 3" lift and was wondering if I needed to purchase uca's in order to clear bigger tires (33's). The truck is pretty much going to stay on road and I have no current alignment issues. So if I get rims with proper backspacing can I skip the uca's?. If so what backspacing is required? If not I have shopped around and I was considering purchasing the uca's light racing offers. Any and all help is appreciated and I can take pics upon request.
    Thanks,
    Silva
  2. Jun 26, 2010 at 11:37 AM
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    If you have 3" up fornt.....you do have allignment issues, you just don't know it yet. It will definetly be noticeable when you slap on bigger tires. I would recoment the LR UCA....best product for the money.
  3. Jun 26, 2010 at 11:42 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    It would be great to hear from someone that has "trail tested" the Light Racing - I don't mean fire trail tested, I mean some real trail testing. Anyone? Please... I would love to have a 'sealed' joint and the adjust-ability that these babies have!
  4. Jun 26, 2010 at 2:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you off road alot, opt for a Uniball UCA, like the Total Chaos. Dont let the exposed uniball fool ya. The military uses Uniball joints on alot of their vehicles, and mud, and other gunk dont hurt them. They are much stronger than an ball joint. Personally, I have had Mud, fine dirt, left my UCA's under water for a solid 4+ hours, and even had concrete dry on them, and they are still tight (3 years on vehicle), and squeak free. I have sprayed the uniball 2 times in the last few years with a dry teflon spray lube, just for general maintinance.
    If your looking for alingment correction on a budget, and do moderate off roading, the LR UCA's would be fine. If you spend more time off road, or need more travel, get a Uniball UCA, Like TC, Camburg, or Icon.
  5. Jun 26, 2010 at 3:37 PM
    HBMurphy
    Paul
    So California Coast
    None
    Thanks!
    20k on my A/P 1.25 and I have not yet been able to get less than about 4.7 Caster and would like to see something that I can get lower than that.
  6. Jun 28, 2010 at 3:06 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    COMPLETELY AGREE - I have the LR UCAs for alignment
  7. Jun 28, 2010 at 7:36 PM
    HBMurphy
    Paul
    So California Coast
    None
    You completely agree with the point that they are not meant to be wheeled that much or that they are good for budget correction of alignment? :confused:
