Question that I dont think is on this site... yet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tensecondchevelle, Sep 27, 2013.
  1. Sep 27, 2013 at 4:36 PM
    tensecondchevelle
    tensecondchevelle [OP] Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
  2. Sep 27, 2013 at 4:38 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Just get a thermometer and place accordingly
  3. Sep 27, 2013 at 4:40 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Purely subjective to the surrounding temp.
    An engine bay in AZ is much hotter than one in AK.
  4. Sep 27, 2013 at 4:40 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Engine gets 185 - 200*
  5. Sep 27, 2013 at 4:42 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Coolant runs about 203, so the air coming through the radiator will be cooler than that.
    Hottest area will be the exhaust manifolds, but the engine cover and sheetmetal surrounding the engine will be 200 or lower.
  6. Sep 27, 2013 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Between 200 and 225* (top of hood after running) is what I have seen in the summer time out here.
  7. Sep 27, 2013 at 4:48 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Figured the Jeep would get up to 451...
  8. Sep 27, 2013 at 4:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive seen them get hotter.....
  9. Sep 27, 2013 at 4:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, It seems the Jeeps happy temp is right at 200*, whereas the Tacoma seemed to run from 185* in the winter, to around 195-205 in the summer.
  10. Sep 27, 2013 at 4:54 PM
    tensecondchevelle
    Eric
    Mesa Arizona
    What i'm doing is wrapping up some wires that connect into the headlights.
    I think the guy that installed my headlights about 6 months ago used a cheap, or non heat resistant, tape that melted all the sticky stuff right off.
    I want to get it all wrapped up tight again before I get condensation in the housing.
  11. Sep 27, 2013 at 5:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Once warmed up, I've never seen mine below 198.
    It's typically 203 cruising straight and level, drops to 198 climbing a hill with the AC on... go figure.
  12. Sep 27, 2013 at 5:02 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Apparently, pretty f**king hot...
