Question: the TSB Suspension fix...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheRagman, Dec 3, 2008.
  1. Dec 3, 2008 at 7:08 AM
    TheRagman
    TheRagman [OP] New Member
    Sterling, VA
    09 Prerunner SR5 V-6 DC
    Access Literider Tonneau
    So, this TSB was for 2005-2008, right? Does anybody know how or whether they resolved this problem for the 2009 models? My '09 PreRunner has rear leaf springs with only 3 leaves. Just curious...
  2. Dec 3, 2008 at 7:10 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    they'll make you suffer with it for another 8-9 months and then they will add you to the TSB. You should call the Customer Service number and complain. That probably helps to speed up the process. You could also try talking to your local service rep and explain to him that all the part numbers are the same, but he doesn't have to do anything.
  3. Dec 3, 2008 at 7:29 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    They added the 2008 to the TSB around October 1st. Probably be right around then next year. Try to stay under 36000 miles before then.
  4. Dec 3, 2008 at 9:04 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    Since this TSB has been a known issue for so long does anyone have an idea why they didn't fix the 2009s during production? My 2009 4x4 Sport v-6 access cab has the same 3-leaf rear end.
  5. Dec 3, 2008 at 9:06 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    Most people don't get it done. Most people go for unloaded ride quality.
  6. Dec 3, 2008 at 3:29 PM
    Raylo
    MD, USA
    OK, that makes a little more sense. It is sort of an optional TSB depending on the owner's use and preference. I have to say I am happy with the ride as is and will usually not haul anything heavier than some mountain bikes and kayaks. But if the occassional heavy load of lumber and time cause these springs to sag, I won't be happy. I guess I'll see how it goes. In any case a set of leaf springs is not a huge expense or difficult job to do down the road. I already have the good shocks with the sport package.
  7. Dec 3, 2008 at 3:41 PM
    Tino4980
    Tino4980 Well-Known Member
    Bermuda Dunes, California
    09 TRD Off Road 4x4, 6 Speed , Magnetic Gray
    I have a 09 and had my TSB Done a month ago :D , you just have to tell them that you have the same part numbers on your 2009 and you have a "HARSH RIDE" , and be cool about it dont be to aggresive when you go to them, i bought my truck a month and a half ago, the 4 leaf springs are so much better , it helps if you take the TSB form with you and show them
