question....Y-pipe or long tube headers
Discussion in 'Performance and Tuning' started by NtacomaR, Jul 30, 2012.
  1. Aug 3, 2012 at 7:19 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You shouldn't need the MAF calibrator for any of your options. That's for the intake (it can help with aftermarket setups but only in open loop operation but it's not required). I think you're thinking of the O2 simulator and you shouldn't need those since your cats are staying in place. The shorties should have the bungs welded in place for the sensors.
    Just so you know, there was a company who offered stainless steel shorties at a really good price. I'll try to find the link.
    Edit: http://www.tacomaworld.com/forum/2nd-gen-tacoma-marketplace/224688-avs-fabrication-4ll-header.html
  2. Aug 3, 2012 at 7:22 PM
    NtacomaR
    NtacomaR [OP] Well-Known Member
    nick
    sparks
    2012 Tacoma Baja
    suspension, wheels, rims, trd exhuast, CAI
    ok thanks for the help man i do appreciate the graph...that def made my mind up. I got my intake coming in like 3 days, so ill be excited to install the headers here in the near future
  3. Aug 4, 2012 at 10:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Interestingly, I was underneath and '11 yesterday, messing with the driveshaft. I decided to take a good look at the catback. They have improved greatly over the earlier models. Not sure exactly when, but the catback used to be 2.25" diameter. On that guy's '11, it was 2.5" all mandrel bent, and very nice. If the is a restriction in it, it is strictly due to the muffler.
    So to upgrade your catback to a TRD one, unless you just really want to, I would only change the muffler, to alter the sound to your liking.
    The factory y-pipe however, had not changed, and was still the same restrictive design.
  4. Aug 5, 2012 at 8:55 AM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    ok good info. thanks man. yea i have the TRD cat back on it now...but i def want to change the TRD muffler to a magnaflow or something a littler more "mean" sounding...but yea im going to do the shorty headers then if i want a little extra "umph" im going to upgrade the Y-pipe. and then thatll probably be all ill be doing to it performance wise...i really wanna get it professionally tuned though also. but i heard the Price vs Power Gains isnt worth it
  5. Aug 5, 2012 at 9:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds like a good plan man.
    On the down side, there are currently only 'wire-in' style units available for your year model truck. At that point, unless you wanted to stay on the lower cost of things with something like the MAF Calibrater from URD, it would be very expensive to get an EMS system that someone can professionally install and tune. :(
  6. Aug 5, 2012 at 9:28 AM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    shoot. ok, yea i was going to talk to the shop that is going to dyno my b4 and after results from the airaid CAI, if they could tune it...but if its that pricey then ill most likely wait ha...
  7. Aug 5, 2012 at 9:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. Aug 5, 2012 at 9:47 AM
    NtacomaR
    nick
    sparks
    2012 Tacoma Baja
    how hard are those to install? and does URD tune it to my Mods?
  9. Aug 5, 2012 at 3:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD sends it pre-loaded with a basic map for your mods. Then you can choose to leave it be, or fine tune it yourself.
    The instructions are pretty clear. Just takes some wiring. But you need to make sure that urd has the instructions for the '12+ models.
  10. Aug 5, 2012 at 9:48 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    I went into this in your other thread as well, butI highly recommend the maf cal. I also highly recommend headers and an intake to go with the maf cal. I had my custom catback and intake on for almost a year and saw some, but minimal gains. Once I put on the LT headers and the maf cal, i saw a huge improvement.
    If I had to saw, the LT headers gave me the most gain. No low end loss. Believe me I would notice it around here with constant hills and curves, usually at the same time. I hold my speed much better now with the headers.
  11. Aug 6, 2012 at 5:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good words TacomaGus. :top:
    I met a guy member Thursday who said he had before and after dynos of just the maf cal. Said he gained 15 whp and something wtq. His name is TX SR5. Just haven't gotten those dyno graphs yet.
  12. Aug 6, 2012 at 6:07 AM
    TacomaGus
    Gus
    Morgantown, WV
    that would be a great addition!
