Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaman63, Apr 5, 2018.
  1. Apr 5, 2018 at 11:01 AM
    Tacomaman63
    Tacomaman63 [OP] Well-Known Member
    Stan
    2004 tacoma TRD 4x4
    step bars grille guard
    My door lock on the drivers side will unlock with the keyless entry but I can’t unlock all the doors at once with my key like I can on the passenger side. What would that problem be a fuse maybe? Or something inside the door panel?
  2. Apr 5, 2018 at 11:25 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    ^^ What he said. I push once to unlock driver then again within a few secs to unlock the other doors.
    Pro tip: State your issue/ask your question in the thread title so people know what the thread is about. One-word titles like "Question" or "Truck", or my favorite "???," are pretty useless.
    Crow_of_judgement likes this.
  3. Apr 5, 2018 at 11:31 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Not that useless: he got two (likely) helpful responses within about 20 minutes... :devil:
  4. Apr 5, 2018 at 11:39 AM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    Right! What I’m talking about is when I put my key in the door and turn it to the right only the drivers door unlocks. When I do the same with the passenger door all the doors unlocks.
  5. Apr 5, 2018 at 11:43 AM
    jbrandt
    Justin
    Who puts their key in the door? What, is this 1985 or something? :D
    But I think that's normal.
    I'm sure there's some hack where yo can reprogram the ECU or something, but probably not worth it.
  6. Apr 5, 2018 at 12:20 PM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    I guess I’m just old school :p
  7. Apr 5, 2018 at 2:35 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Did you try turning to unlock position twice? I think it is a safety feature to only unlock the drivers, keeping someone from opening another door. Same as with the key fob.
  8. Apr 5, 2018 at 4:41 PM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    Yes I tried it twice, I forgot I had to turn it twice with the key to unlock all the doors, it won't unlock all the doors when I turn it twice
  9. Apr 5, 2018 at 6:49 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Integration relay
  10. Apr 5, 2018 at 7:54 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I believe it's working correctly or both my truck and Sienna are both failing the same way.
    It would make sense to unlock both (or all 4-5) from passenger side with 1 turn because it assumes there's a driver, yet only unlocks the drivers door with 1 turn because you could be alone, if not, then turn twice from driver's door to let in others....or not if they're irritating you.
  11. Apr 5, 2018 at 7:59 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You can change the unlock feature using the Toyota Tech Stream diagnostic soft ware. Its located under the "customization" header. It's one of the 1st things I change when I get a new Toyota. The second is to turn down the "key in the ignition" chime. They come from the factory set at their loudest.
  12. Apr 5, 2018 at 10:06 PM
    callmeammo
    callmeammo Well-Known Member
    Where do you get the software and what do you need to run it?
    I hate the chirping on my alarm.
  13. Apr 5, 2018 at 10:14 PM
    koditten
    Kirk
    Central Michigan
    It can be found on Amazon or Ebay. Its pretty reasonably priced. You need to have some computer skills for it to work, but all questions can be answered using the internet.
  14. Apr 7, 2018 at 8:23 AM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    I hate hearing that key in the ignition chime and it is loud. I read on here you can unplug it under the dash also two white plugs, sounds simple doing it that way. ;)
