Questions??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MOB 08Tacoma, Feb 24, 2010.
  1. Feb 24, 2010 at 5:42 PM
    MOB 08Tacoma
    MOB 08Tacoma [OP] Active Member
    whittier ca
    AFE intake,Running Boards,Brush Guard
    hey guys i'm new to lifting up trucks and i have a few questions,My first question is what are the best lift kit for a reasonable price,comfort? How much do you guys think ill spend?Also i have another question i wanna make a straight pipe exhaust and cut it after the axel, how will that sound?Do you guys recommend i should just get the 3" toytec spacers?
    I have a 08 Tacoma double cab 2wd.
    Thanks
  2. Feb 24, 2010 at 5:47 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    If you can afford it don't use spacers.
    If all you can afford is spacers, then keep saving your money.
  3. Feb 24, 2010 at 5:49 PM
    MOB 08Tacoma
    whittier ca
    how much will a full strut and springs cost?
  4. Feb 24, 2010 at 5:54 PM
    DDD
    Derek
    Santa Clarita, CA
    Look at some The Ultimate lift kit is adjustable in the front. 1" to 3.5"
    The OME lift kit is also good but not adjustable. 3"
  5. Feb 25, 2010 at 5:21 PM
    MOB 08Tacoma
    whittier ca
    alright im thinking of buying the bilstein 5100 but i dont know what springs to get?
    im looking for a 3" lift
    need some help
  6. Feb 25, 2010 at 5:40 PM
    DDD
    Derek
    Santa Clarita, CA
    If you want 3 inches, get the OME 885 springs with top plate spacer, and set the 5100s at the 0 or bottom setting.
    Or to get 2.5 inches then use the stock springs and set the 5100s at the 2.5 setting.
  7. Feb 25, 2010 at 5:53 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    subscribed, i'm in the same boat.
  8. Feb 25, 2010 at 7:17 PM
    MOB 08Tacoma
    whittier ca
    i cant find the OME 885 springs.
    so i can use the stock springs but it will be a 2.5" lift?
  9. Feb 25, 2010 at 7:18 PM
    MOB 08Tacoma
    whittier ca
    Anyone have pics of there tacoma lifted with stock rims and tires?
  10. Feb 25, 2010 at 7:23 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Stock rim painted black with a 3" spacer lift and rear AAL (Add A Leaf)
    To have it to do over again I would have waited and did a true suspension lift...(struts and coils :) )
  11. Feb 25, 2010 at 7:26 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    not to be mean but there is a search function :D and welcome to the forum! glad to see new members joining all the time!
  12. Feb 25, 2010 at 7:29 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    coils are here :: toyteclifts.com ..they are options in the kits
  13. Feb 26, 2010 at 8:02 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    If you want to go with the OME gear, I would stick with just that OME.
    That means, both front shock and coil should be OME, that way your ride is the 'best' it can be on the OME spring.
