quick lift question...I know...another one
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bridgcat, Oct 5, 2011.
  1. Oct 5, 2011 at 12:35 PM
    bridgcat
    bridgcat [OP] Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    Ok...so now I am considering getting the OME lift with 885 coils instead of the RCD kit because the more I think about it the more I don't want to cut my cross member. My question is, is do I need the top plate spacer to get the full 3" of lift or do I not need them. I want to clear 285's. I know I will need to trim and thats not a problem. Also, do I need rear axle shims? Basically...what all do I need to buy along with this kit? Thanks guy!
  2. Oct 5, 2011 at 12:38 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I didn't add the spacers and got 2 1/2" up front with the 885x coils on my DCLB .
    If you are doing Dakars out back , add centre pin collars to allow you to use axle shims later if you need them .
  3. Oct 5, 2011 at 12:39 PM
    bridgcat
    Alabama
    Would the regular add a leaf be ok to keep it level? Thanks OZ.
  4. Oct 5, 2011 at 12:46 PM
    OZ-T
    Peter North
    British Columbia
    Yes
    I have about 1 1/2" of rake with the Dakars .
    The Daks got me about 2 3/4" over stock height .
  5. Oct 5, 2011 at 12:54 PM
    bridgcat
    Alabama
    Thanks for the help OZ! How are you cv angles? Any trouble with them?
  6. Oct 5, 2011 at 12:56 PM
    OZ-T
    Peter North
    British Columbia
    Good , no issues .
    I did add LR UCA's as well .
  7. Oct 5, 2011 at 12:58 PM
    bridgcat
    Alabama
    Would you recommend the sway bar relocate?
  8. Oct 5, 2011 at 1:05 PM
    OZ-T
    Peter North
    British Columbia
    I didn't need it . The OME coils aren't supposed to contact the sway bar , but I have heard of people having it happen .
    bjmoose had his contact and he did the relocate
  9. Oct 5, 2011 at 1:08 PM
    bridgcat
    Alabama
    Thanks man! +1 rep for you sir!
  10. Oct 5, 2011 at 1:15 PM
    OZ-T
    Peter North
    British Columbia
    No problem
    Good luck .
  11. Oct 5, 2011 at 1:17 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    Just thought I'd add my 2 cents. I installed my OME kit (884) without spacers and aftermarket UCA's at first. After I saw it and drove for about a month I wanted more lift up front and a better alignment so my steering didn't feel so loose. I added the top plate spacers and LR UCA's and love it. Rides better than stock and no vibes or other issues. I did order extended SS brake lines for the rear though, don't know if they're a must have but I decided to not risk ripping them while driving :)
    I also never had to fool with relocates or axle shims. Hope this helps!
