Quick question about 5100 install
Discussion in 'Technical Chat' started by toyodajeff, Mar 13, 2012.
  1. Mar 13, 2012 at 11:03 AM
    toyodajeff
    toyodajeff [OP] Well-Known Member
    jeff
    canton Ga
    06 reg cab sr5
    General lee horn mod, Bilstein 5100's and maxtrac 4 inch lift spindles. omd spring rebuild w/ s10 springs kenwood h/u and cb, warn trans4mer brush guard level 8 tracker wheels and cooper s/t 33's
    I installed my bilstein 5100's yesterday and i had to use a pickle fork to seperate the steering ball joint where it bolts to the spindle. ( I think its called a tie rod end but not sure). i sqeezed alot of grease out of it and possibly poked a small hole in it with the pickle fork. Can i replace just the rubber boot or is it attached to the tie rod? does the hole even matter that much if i dont mud bog the truck and only do light offroading?
  2. Mar 13, 2012 at 6:43 PM
    toyodajeff
    jeff
    canton Ga
    06 reg cab sr5
