quick question about ipod adapter...
Discussion in 'Audio & Video' started by tommyboy2929, Mar 7, 2008.
  1. Mar 7, 2008 at 11:11 AM
    tommyboy2929
    tommyboy2929 [OP] Active Member
    sacramento cali.
    2008 PreRunner SR5 Double Cab TRD Off Road
    Sport Hood(hood scoop), Chrome Nerf Bars, wheels, k&n intake, magnaflow exhaust, pioneer D3, focal speaker, and alpine pdx amp. soon to be more!
  2. Mar 7, 2008 at 11:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That looks like the ipod2car unit.
    I have it with 6-disc changer.
    The factory 6-disc changer has an additional port on the back of the head unit to plug in another disc changer if you want. The ipod2car plugs into that port and you utilize it like an additional CD changer. Your factory unit will remain usable.
    Make sure you get the PXDP unit. I've heard the new generation units don't work on the newer tacomas.
    Here's a writeup on it:
    http://aaronlinsdau.com/gear/articles/ipod2car.html
  3. Mar 7, 2008 at 11:36 AM
    tommyboy2929
    sacramento cali.
    cool thanks for the help... so is the one i was looking at ok? i dont know what the PXDP unit is.
  4. Mar 7, 2008 at 2:10 PM
    Janster
    Jandy
    Lancaster, PA
    The one you were looking at - looks to be the same unit as I have.
    It's made by Peripheral Electronics and the unit itself is called PXDP.
    (you don't want the PXDP2)
  5. Mar 7, 2008 at 5:17 PM
    tommyboy2929
    sacramento cali.
    cool thank you very much!
  6. Mar 9, 2008 at 12:46 PM
    AK Backcountry
    AK Backcountry Well-Known Member
    Eagle River AK
    08 TRD Off-Road
    Snugtop, Scangauge II, iPod Adaptor, Redline Hood Struts, Removed Secondary Air Filter, De-badged, AFE Drop In, Westin Oval Steps Future: Locker Anytime
  7. Mar 9, 2008 at 2:12 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    05-08 radios are the same, in point of fact 98-08 toyota factory radios are all compatible with usa spec pa-12 TOY. The guy at the audio shop was just trying to screw you out of more money.
  8. Mar 9, 2008 at 2:49 PM
    AK Backcountry
    Eagle River AK
    08 TRD Off-Road
    Hey Mav
    Thanks for the response. I also sent a PM to rmdo311 because after I sent the post I found a thread he had commented on. I think he is using the PA12TOY on an 08.
    I figured as much about the local guy but I wanted to check to make sure. Thanks again.
    AKBackcountry (Kevin)
    PS. You still running the ECO device?
  9. Mar 10, 2008 at 11:07 PM
    markustyson
    markustyson Member
    Victoria, BC
    2008 Tacoma 4x2
    I have read all (at least I think I have) of the threads about ipod adapters/interfaces. However, none of them talk about the stock, single CD radio. I don't have the 6-disc changer. Am I to assume that products such as the USA-Spec, ipod2car, and GROM ONLY work with the 6 disc-changer? Anyone out there with a stock, single disc radio that has installed an ipod adapter?
    Thanks!!
  10. Mar 11, 2008 at 12:24 AM
    tommyboy2929
    sacramento cali.
    yea the guy i just bought my ipod2car from had it on his stock single disk and it worked fine. i just installed it on my 6disk changer and it transfered right over.
  11. Mar 11, 2008 at 5:57 AM
    Janster
    Jandy
    Lancaster, PA
    This write-up (same as listed above) is about installation on a single CD unit.
  12. Mar 11, 2008 at 1:22 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    So when the iPod is connected, it will be the "CD" and when unattached, then a CD can be inserted and played? What if a CD is in, and the iPOD is attached?
    Thanks..
  13. Mar 11, 2008 at 1:39 PM
    maverick491
    South Jersey
    When the ipod is attached it will be CD-1 or CD1 (too lazy to go outside and look), but regardless you would just hit the disc button on the radio, and it would first go to the cd player if there is a cd in it, then if you hit the button again it will go to the ipod.
  14. Mar 11, 2008 at 3:18 PM
    Janster
    Jandy
    Lancaster, PA
    Yup...
    CD = to play a CD in your 6disc changer
    CD1 = to play the ipod
    **this is using the ipod2car. I don't know if CD1 is the same for other adapters or not.
  15. Mar 11, 2008 at 7:43 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Yes, it works the same with the Metra adapter.
  16. Mar 12, 2008 at 12:49 PM
    chris L
    chris L Well-Known Member
    06 taco dbl cab , debadged 4x4 trd off road
    and it works the same with the grom unit .
  17. Mar 12, 2008 at 5:20 PM
    surftodd
    surftodd Well-Known Member
    2007 Tacoma
    3 inch Trux suspension lift Upgraded Bilstein Shocks Upgrade spring pack Custom Rock-Crawler Wheels 32 inch Kumho MTs Rear Jumper Seat- makes truck a seven person vehicle Tow package Rear Fog lights New Roof Rack Running Lights Cargo Extender Rack Bed Cover
    i just put this in my 07 today and it is great!....the installation took about 25 minutes, the hardest part was deciding where to bring the cable out of the dash to hook into the ipod. I ended up drilling through the top of the small storage compartment right to the right of the steering column. the pod fits in there perfectly and then it can be extended(pulled) all the way to the passenger side-not that I would let my pass. pick the driving tunes.
    anyway, I am very pleased with the adapter and the easy install
