Quick question about muffler!!
Discussion in 'Off-Topic Discussion' started by Dr_Kevorkian, Dec 17, 2010.
  1. Dec 17, 2010 at 10:40 PM
    Dr_Kevorkian
    Dr_Kevorkian [OP] Well-Known Member
    California
    2nd Gen Pyrite Mica AC
    So the guy whos doing my magnaflow wants to know the following information and i have NO CLUE whatsoever so i was hoping someone can help me out:) On my 2004 taco, do i need a center in center out? offset in center out? OR offset in offset out?
    Thanks in advance!
  2. Dec 17, 2010 at 11:25 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    That is all up to you and how you want your exhaust setup... It won't affect anything, but more dependent on how you want to route your exhaust. If you want it in the same place center in/out would be fine and he could put in pipe to close the gap
  3. Dec 18, 2010 at 9:44 AM
    Dr_Kevorkian
    California
    so center in/out would be the best/common one?
  4. Dec 18, 2010 at 9:55 AM
    booboy
    booboy Well-Known Member
    PaCiFiC nOrThWeSt
    2010 TrD SpOrT 4x4
    Do you want to run one muffler or two?
  5. Dec 18, 2010 at 9:57 AM
    memario1214
    Colton
    Missoula, MT
    That would be the common route yes... But if you look at your exhaust pipe coming down through the pickup, if the pipe comes straight back through and doesn't move left or right, center in/out will work just fine. Just look,you'll be able to see whether or not the pipe moves. If worse comes to worse, take a couple photos, one from one side of the muffler, one from the other, and one straight underneath and I will tell you what you need...
