Quick question on your opinion on lift//tires
Discussion in 'Suspension' started by JohnMatrix, Dec 23, 2010.
  1. Dec 23, 2010 at 2:33 PM
    JohnMatrix
    JohnMatrix [OP] New Member
    Westminster, CA
    05 Tacoma Regular Cab w/Shell
    I have a stock 2005 Tacoma, regular cab, base model. Quite frankly I am tired of looking at it. Gotta have it look like a pre-runner. I don't need it off-road capable, im simply going for visual effect.
    Basically what I want from you veterans is a good estimated guess on what you think a 3" lift kit // rims tires will cost. I am not asking for a researched answer, or you to look into it, (I will search the forums and the web myself for specifics) but your guesstimate for a simple affordable lift that is of some quality. Nothing half-assed.
    Lay it on me~
  2. Dec 23, 2010 at 2:38 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    lift > 500-700 for parts, 400ish more if you have someone install it
    tires > 800
    rims > 400-500
  3. Dec 23, 2010 at 2:57 PM
    JohnMatrix
    Westminster, CA
    I should have mentioned, does a 3" lift allow for my wheel wells to fit 17" rims//tires (265/65 R17 tires) ?
  4. Dec 24, 2010 at 8:40 AM
    CopDoctor
    08 335i
    easy. you could fit 285/75 with a bit of trimming but 265 will have no problem at all
  5. Dec 24, 2010 at 8:44 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Tires and rims right on, but you could go with billies in front or a spacer for real cheap, throw and aal in back worst case 300.
    Although are you a 5 lug? Do the billies fit on 5 luggers? If not spacers I think should.
