QUICK QUESTION - The 3 transfer case shaft positions please...
Discussion in '1st Gen. Tacomas (1995-2004)' started by DC92T, Nov 25, 2018.
  1. Nov 25, 2018 at 2:46 PM
    DC92T
    DC92T [OP] Well-Known Member
    03 TACO 33" BFD's SLOWPOKE
    Suspension lift, towing package with air bags rolling on 33" BFG A/T's
    Hi guys, still working on my 03 Taco, Just got the used transfer case with a good actuator in today...
    I read it 3 or more times, but I CANNOT find the post that stated:
    ""Shaft all the way forwards is **** 4WD""
    ""Shaft all the way back is **** 4WD""
    and ""Shaft in the middle is **** 4WD""
    I'll make a big write up when I'm done, please help me out if you could, thank you...
    DC
  2. Nov 26, 2018 at 7:51 AM
    Stm82
    Stm82 BRAAAPPP!!!
    Mb. Canada
    95.5 2.7 5 speed 4x4 reg cab
    33x12.5x15 Nitto Trail Grapplers on M/T 15×8 3.25" Bs 3" Toytech front Mystery add a leaf back with random shocks Bush whacker cutout flares (extra firewall smash) Side dump exhaust Washer fluid relocate 91 (or so) bucket seats and console Twin stick transfer case Toyota elocker
    On the left if your in the drivers seat is the high low shift shaft. Low is backwards high is foreward neutral is in the middle. The right shift shaft is 4x4 back is 2wd forwards is 4x4.
    This is looking at the parts the shifter or actuator move. Not the position of the shift lever .
    I don't have a pic of the internals but this is the twin stick setup which works them independently.
  3. Nov 26, 2018 at 9:01 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You don’t have the knob? It’s labelled.
    If you have J-Shift:
    • 2HI — Resting Position
    • 4HI — Pull Down
    • N — Pull Down, Right, and Up
    • 4LO — Push Up from N
    If you have Push-Button 4WD:
    • 4LO — Push Buttom, Pull Up
    • N — Middle Position
    • 4HI — Push Button, Pull Down
    Stm82 likes this.
  4. Nov 26, 2018 at 9:24 AM
    Stm82
    Stm82 BRAAAPPP!!!
    Mb. Canada
    Mine are shift dog positions. (Under shift lever and actuator) Bartmaster1234's are shift lever and button positions.
  5. Nov 29, 2018 at 2:47 PM
    DC92T
    Hello, I think you're on the right track. What I MEANT - It seems there are 3 positions that the linear shaft, driven by the electric actuator, has for the different selections.
    It seems to have 3 positions and I had read that 1 was 4WD-H, 2 - 4WD-H, and 3 - 2WD high. I just cannot find that same post again...
    Not the gear shift in the cab (I'm not that dumb, YET!!), rather that shaft your actuator runs.
    Thank you everyone, I truly appreciate ALL of your help guys...
  6. Nov 29, 2018 at 2:51 PM
    Stm82
    Stm82 BRAAAPPP!!!
    Mb. Canada
  7. Nov 29, 2018 at 2:57 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    ...... :annoyed: ......
    Stm82 likes this.
  8. Dec 2, 2018 at 11:12 AM
    DC92T
    No one recalls the 3 positions the actuator shaft moves the transfer case forks?? Forwards, middle, back that's all; The guy even boasted that with a 12mm wrench, he can get a Toyota out of the trails just by moving that shaft in the 3 spots.
    Well, I'll just start searching again because I read it in a few threads, thanks anyhow...
  9. Dec 2, 2018 at 11:24 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Are the positions mentioned in posts above not correct?
  10. Dec 2, 2018 at 11:29 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Use a picture. I'm betting the mental image isn't coming through, I get you but I don't have that part.
    Your new (to you) one wasn't attached in the correct orientation?
    Maybe when searching use the term 'clocking'. I didn't find anything either looking up your key words.
  11. Dec 2, 2018 at 11:31 AM
    DC92T
    I must be overlooking a reply?? It seems the 1st people that replied thought I meant the shifter in the cab. I mean the rod actuated by the electric motor in your transfer case. The motor places it forwards, back, or in the middle to "engage" your front drive shaft.
    Okay, I wrote this reply, then double checked. Everyone is referring to the shift knob/lever locations in the cab, I'm not seeing that answer....
    I'll find it and post it here to help with the confusion...
  12. Dec 2, 2018 at 11:40 AM
    cruiserguy
    Elijah
    SEKS
    Oh okay, hopefully that helps clear up what you're looking for then. Let us know
  13. Dec 2, 2018 at 11:44 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    DC92T[OP] likes this.
  14. Dec 2, 2018 at 12:29 PM
    Indy
    Indy Master of all I survey.
    Looking at the OP, not sure what he's asking as every position = 4wd...
    FWIW every position will always be 2wd, the only thing that gets moved is whether or not the front output is engaged.
  15. Dec 2, 2018 at 12:54 PM
    Stm82
    Stm82 BRAAAPPP!!!
    Mb. Canada
    Mine is referring to the positions of the the shift dogs inside the tcase... the picture does yes show the shifter but it also shows what the two shafts and shift dogs you find below it do.
    If you did have a the actuator fail it could be pulled off on a trail and select 4x4 or 2wd by moving the right shaft.
  16. Dec 2, 2018 at 7:17 PM
    DC92T
    Okay, I figured out how to get pics on here to resolve any confusion.
    I don't know how to time the contacts, or the actuator shaft to gear. This is all on my transfer case... 1st gen, it's different than all the other info I can find...
    I need to time the rotary contacts, and time the gear onto the rack. There must be a procedure somewhere how to do this...
    Help....please...
  17. Dec 2, 2018 at 7:19 PM
    DC92T
    See this last photo above ^ It needs to be orientated in there correctly, there are no match marks like I normally see Toyota supply us.
    Thats the shaft I am asking the 3 positions for in photo #1 and #2
    The 1st 2 photos are for timing that pinion gear on that rack...
  18. Dec 2, 2018 at 7:40 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
  19. Dec 2, 2018 at 8:04 PM
    ectrd
    ectrd Well-Known Member
    '04DC
    4 tires, a steering wheel & a seat
    Looks like my old jeeps T-10 , full forward on is gonna be 4Lo , pull back to first (center like position) will be 2Hi (or neutral for transfer depending which lever engages/disengages )& all the way back 4Hi, I think... I'm just going to shut up cause now I'M confused...:anonymous:
    As far as anything accuating they should re-synche when energized like in a Elocker
  20. Dec 3, 2018 at 9:13 AM
    DC92T
    This is just a used one I picked up...
    Well, todays the nice day so I'll just try and we'll see what happens
