Quick spark plug question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter500ky, Dec 22, 2010.
  1. Dec 22, 2010 at 6:59 AM
    Hunter500ky
    Hunter500ky [OP] Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    No one around me does not have the stock denso they have the iriduim power number IKH20.
    So will they work or should I go with ngk
  2. Dec 22, 2010 at 7:01 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    On phone at store sorry meant none has the stock plug
  3. Dec 22, 2010 at 7:10 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Use NGK.. Or go to the dealer. Dont use the irridium plug. Wrong application. No Bosch, Champion, Autolite. Use NGK or Denso!!!!!!:lalala:
  4. Dec 22, 2010 at 7:11 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
  5. Dec 22, 2010 at 10:16 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Here is the list from Denso site
    http://www.globaldenso.com/cgi-bin/...?name=TACOMA&filename=4w-63.txt&action=search
    TOYOTA
    TACOMA [​IMG]
    YEAR 2007 ENGINE TYPE V6 LITER 4.0 CC 3956 ENGINE DESIGNATION 1GRFE STANDARD PLUG NO K20HR-U11 STANDARD PLUG STOCKNUMBER 3381 PLATINUM PLUG NO - PLATINUM PLUG STOCKNUMBER - IRIDIUM LONG-LIFE PLUG NO SK20HR11 IRIDIUM LONG-LIFE PLUG STOCKNUMBER 3421 IRIDIUM POWER PLUG NO IKH20 IRIDIUM POWER PLUG STOCKNUMBER 5344 GAP 0.044
  6. Dec 22, 2010 at 10:29 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    if you want i can get them from my stealer and ship them to you
  7. Dec 22, 2010 at 10:36 AM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i see no problem with running iridium. if they are the same heat range they should work no problem. the only disadvantage is cost, but the advantage is exponential durability. unless someone gives verified information as to why iridium was not used for this application from the factory due to anything more than a cost saving measure for Toyota, i'll be convinced there is absolutely no problem running them.
    that said, i don't know enough about the denso line to realize the differences between their long life and other iridium plug versions.
    OP, advance auto parts has PDQ - if you order the plugs today they can have it tomorrow at no additional charge, provided they have it in one of their distribution centers.
  8. Dec 22, 2010 at 12:27 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Got the OEM ones, had to go to stealership :(
    32$ o well no worries changed them and put in a K&N filter runs better!
