Quick verification- 285/75/16 no go on stock suspension?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alexc, Jul 3, 2013.
  1. Jul 3, 2013 at 9:23 AM
    alexc
    alexc [OP] Well-Known Member
    Alex
    Tampa, FL
    Found a good used set of 285/75/16's for a good price but I'm still currently on stock suspension. Just wanted to verify they will NOT fit?
    Thanks,
    Alex
  2. Jul 3, 2013 at 9:25 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2006 Infiniti M35x
    Correct, unfortunately. Unless you don't plan on turning or going over anything bigger than a speed bump.
  3. Jul 3, 2013 at 9:28 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Sure they'll fit, you'll need to chop the cab mount and trim a bunch of plastic, and probably beat your pinch weld back, but they should fit. The real question will be your wheels, if they are the stock wheels, you'll need some spacers to bring those tires out at least an inch, but 1.25 would be preferred.
  4. Jul 3, 2013 at 10:00 AM
    alexc
    Alex
    Tampa, FL
    Roger, thanks. Guess I will stick wih stock size and look into 5100's and spacers
  5. Jul 3, 2013 at 10:00 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I could fit my 285s right now with less than stock height.
  6. Jul 3, 2013 at 10:07 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I'm running my 285s with stock wheels and spidertrax wheel spacers and 5100s at 2.5. Yea you will need some lift and also be ready to chop off some plastic.
  7. Jul 3, 2013 at 12:50 PM
    alexc
    Alex
    Tampa, FL
    If I don't do much off roading, would a decent set of 265's work for most light trails and such? I'm a noob to trucks/ off roading...
  8. Jul 3, 2013 at 12:52 PM
    PB65stang
    Patrick
    Kansas City
    2006 Infiniti M35x
    Absolutely. A lot of the guys who do serious off-roading run 265s. You're going to be fine with a 265/75/16 or 265/70/17.
  9. Jul 3, 2013 at 1:52 PM
    alexc
    Alex
    Tampa, FL
    Why do some go 285 then, looks mostly?
  10. Jul 3, 2013 at 1:57 PM
    PB65stang
    Patrick
    Kansas City
    2006 Infiniti M35x
    The ones who run them would have to say for sure, but yes, I'd guess that looks is about 80-90% of it. You do gain, what, an inch of extra height? So maybe that's part of it too.
  11. Jul 3, 2013 at 1:59 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    It makes a large difference off road.
  12. Jul 3, 2013 at 5:30 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    You gain 1/2" of clearance over 265's...
    David
  13. Jul 3, 2013 at 5:35 PM
    Canazes9
    David
    Texas
    yes
  14. Nov 9, 2013 at 7:17 PM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    05 Speedway Blue PreRunner TRD Off Road
    3 inch lift OME 885, 2in AAL, 5100's, Black Badges, Fog anytime, ABS on/off, window vents, Blacked grill and rear bumper, Afe pro s dry drop in filter.
    There is guy that lives by me that has a 2nd gen stock 4x4 sport running 285s with no wheel spacers. He said it rubbed like a bitch when he first put them on. I showed him that he had less than 1/4 inch between his tire and uca. So food for thought they will fit but not ideal.
  15. Nov 10, 2013 at 4:30 AM
    MrFastener
    MrFastener Fastener Tech
    Richmond VA
    Tacoma Xpro
    3" Toytec Ultimate Adj coil over lift with light racing UCA's, Nittos, remote res rear shocks,
    Heck, on my 2013 with that tire AND the Toytect 3" Lift AND light racing uppers I STILL had to use the Spidertraxx 11/4 spacers. Every sharp turn with some speed, the tires grabbed the upper CA's so bad it almost stopped the truck. I didn't care for the pucker factor without the spacers.
  16. Nov 10, 2013 at 4:37 AM
    MrFastener
    Richmond VA
    Tacoma Xpro
    And don't forget to tell that alignment shop that the caster has to be set well outside of factory specs. I could have used that info a few weeks back.
