Quick wheel question
Discussion in 'Wheels & Tires' started by Revern, May 29, 2008.
  1. May 29, 2008 at 4:46 PM
    Revern
    Revern [OP] Member
    I have an excellent oppurtunity to buy brand new 20''x9 wheels with 6 x 139.7 bolt pattern. Just unsure if they will fit im not sure and was hoping to get a quick answer on here so I can take advantage of the deal if I can. Will they fit???
    Thanks!!
  2. May 29, 2008 at 4:51 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Fit what?
  3. May 29, 2008 at 4:54 PM
    Revern
    Revern [OP] Member
    im an idiot, dont mind me. My 07 tacoma trd double cab short box
  4. May 29, 2008 at 5:01 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    It's ok, we all have our moments. While we're admitting faults, it was rude of me to call you out on your lack of info considering I don't really have a good answer for you. That aside, it is possible provided the backspacing/offset is right. I know there are a couple members here running 20" wheels. With a little patience perhaps one of them, or at least someone more knowledgeable than myself, will chime in.
  5. May 31, 2008 at 7:04 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    As long as you backspacing and offset are correct I don't see the problem. Ideal back space is 4.5 and 0 offset. Most of the rims 9" wide I have seen have a back space of 4.75. Look around on here for someone with 20's and pm them. Sorry I couldn't help.
  6. May 31, 2008 at 4:11 PM
    Revern
    Revern [OP] Member
  7. Jun 1, 2008 at 5:56 AM
    Revern
    Revern [OP] Member
    Sorry for not being a little more educated here but how would I go about calculating the back spacing and offset?
  8. Jun 1, 2008 at 12:58 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    With the rim off of the vehicle, and face down you will need to lay something flat across the rim and measure from that to the center where the lugs would be, that will give you your back spacing. https://www.rsracing.com/tech-wheel.html
  9. Jun 1, 2008 at 1:07 PM
    rick
    rick `
    here ya go rev. stick close to 4.5 bs. the offsets will vary depending on wheel size
    also what wheels are they?
  10. Jun 1, 2008 at 5:40 PM
    Revern
    Revern [OP] Member
    New still in the box 20 x 9 VCT Scarface Chrome Wheels with 6 x 139.7 bolt pattern.
  11. Jun 3, 2008 at 5:37 PM
    Revern
    Revern [OP] Member
    Offset is 17mm. Centre bore is about 78mm
    Does this make sense to anyone and would it work??
  12. Jun 3, 2008 at 8:20 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Center bore is too small tacoma have a 106mm center bore. Our trucks require the larger bore.
