Quick zerk greasing question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Jun 15, 2011.
  1. Jun 15, 2011 at 6:53 AM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Morning guys (n gals). About to grease the nips on ny trucks shafts. Should I drive around a little first to get the old grease warm? Idk if that would make it flow out easier? Thanks
  2. Jun 15, 2011 at 6:55 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    couldn't hurt, but it's probably not necessary. what *will* make it easier is if you have a grease gun with a flexible hose attachment!
  3. Jun 15, 2011 at 7:07 AM
    x2468
    Hmm... the one I bought has an 8" solid hose. How much harder will it be?
  4. Jun 15, 2011 at 7:09 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    not too much, but you'll probably have to roll the truck forward and backwards to get to all the zerks. it's definitely not impossible with the solid hose -- it's just easier with the flexible. you'll be fine!
    props for taking care of your driveshaft! it often gets overlooked...
  5. Jun 15, 2011 at 7:10 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    moderately harder.. youll have to fit the end over the zerks in some tight spots but its still achieveable. you will have to get out and roll the truck back a few inches to spin the drive shaft to get access to the other zerks
  6. Jun 15, 2011 at 7:18 AM
    x2468
    Alright. Well im gonna head down to the local store and grab a hose. Works out since I wanted to pick up wire to do the grey wire mod today anyway.
  7. Jun 15, 2011 at 6:21 PM
    x2468
    alright. got all 8 this mourning. the service manual was a bit confusing. I didn't end up using the schematic as much as i thought i would. It didn't seem to really match my truck. I had the right year and model manual. Man the old grease looked.... old. it was like pencil graphite colored. and I couldn't believe how far my axles moved when fully pumped with grease. They extended like a good inch or 2.
    I pumped until a few tablespoons of old grease came out of each one. It was hard to resist the urge to pump and pump until clean red stuff came out. But i read a few threads that warned of over filling.....
  8. Jun 15, 2011 at 9:20 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    cant really overfill the ujoins, the slip yokes you can tho...
  9. Jun 16, 2011 at 9:37 AM
    x2468
    ya i read a few threads where they were debating if u can over fill the slip yoke or not. some people said no you cant the excess will just come out and others said says you can. Which one was the slip yoke? was that the part of the shaft that extended like a telescope when i pumped grease into it?
  10. Jun 16, 2011 at 9:47 AM
    x2468
  11. Jun 16, 2011 at 9:49 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    i don't think that's a Tacoma Ive looked all over and have never seen those zerks.
  12. Jun 16, 2011 at 9:54 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    dam i really need to grease the zerks on my truck..
  13. Jun 16, 2011 at 10:02 AM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    i have never heard of over filling a zerk....i pumep mine till i saw fresh grease and for the slip yoke i pumped till i saw a good amount of old come out
  14. Jun 16, 2011 at 10:11 AM
    x2468
    ya my slip yokes were like empty.
  15. Jun 16, 2011 at 10:15 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    yeah i didnt really do any research on mine i just pumped till i saw some fresh stuff come out. i knew it really needed it as i had never done it.
    that was like a few weeks ago and its been ok
  16. Jun 16, 2011 at 10:26 AM
    x2468
    i put in a new air filter today. im doing engine oil and filter this week. Now im thinking about doing both diffs, t-case, and tranny... drain or flush not sure....
  17. Jun 16, 2011 at 10:27 AM
    davestaco
    David
    Schofield Barracks
    you got a auto or a stick and how many miles you got?
  18. Jun 16, 2011 at 10:47 AM
    TanSR5x4
    William
    Houston TX
    00 Tacoma SR5 4x4
    yeah i heard flushing the transmission can actually mess up some of the seals and whatnot
  19. Jun 16, 2011 at 11:05 AM
    x2468
    i have an auto with 132k miles.
  20. Jun 16, 2011 at 11:11 AM
    x2468
    ya, im pretty sure that's what happened to my first cars auto tranny. Some shop talked me into doing a tranny flush with an oil change. Sounded like a good idea to me, im always changing the gear oil in my dirt bikes tranny. maybe 5-10k miles later the tranny shit the bed... i was so pissed. the guys that put in a new tranny said flushing it might have kicked up all the old gunk, especially if they did a half assed flush.
    I was reading about tranny flushes here: http://www.gadgetonline.com/TransFlush.htm
    "When not to flush:
    Before draining or flushing you should pull the dip stick and look at the fluid. If it is dark, burnt smelling, and you see little flakes or speck in it, DO NOT FLUSH IT. The fluid and transmission is TOAST, but the transmission just has not figured out it should die yet. In these cases for reasons no one has figured out yet, if you flush a transmission in this condition it will fail right away. Real strange, but that is what seems to happen. If your trans is in this condition just drive it while you save for a replacement transmission. There is no way of telling when it will fail. It might be today, next week, or next year, but it is doomed.
    The goal here is to flush the trans BEFORE the fluid gets rancid. What you are taking out should look like what you are putting in. Do not wait for a color or smell change. My 4Runner Owner's Manual calls for transmission fluid change at 30,000 mile intervals. The industry standard it two years OR 24,000 miles which ever comes first. It is your truck, you decide what is best for you."
    the previous owner said he did something to the tranny fluid right before selling it. i cant remember if he said drain or flush. last time i checked it was still nice and red. maybe i'll be good with just draining it? in a couple weeks i need to drive to canada though with a u-haul full of junk for my dads new house.
