Quivering Hood
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dkamp, Mar 6, 2021.
  1. Mar 6, 2021 at 1:34 PM
    dkamp
    dkamp [OP] Member
    Central Indiana
    2021 SR5 Double Cab 3.5L 4WD
    Hi, New Guy here.....
    On my new Tacoma SR5 I noticed the Hood Quivers, Shakes, Flutters, or moves above 40 mph, or in the Car wash dryer air jets.
    Is this normal?
    It is as if the Top Metal Skin is not secured to the hood under frame structure.
  2. Mar 6, 2021 at 1:36 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Look under the hood to see if the glue failed ..mine flutters and noticed the glue failed at some spots . Shit design don’t know why they just don’t weld them together .
    Skydvrr, tcjacado, 9th and 1 other person like this.
  3. Mar 6, 2021 at 1:38 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sometimes those little blobs of adhesives gives way and the hood skin will separate, if it has they will repair it under warranty.
    Junkhead, tcjacado and 9th like this.
  4. Mar 6, 2021 at 2:02 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Check around for some pictures on here of the "warranty repair" they just flood more glue in there and 90% of the time it looks like a drunk monkey did it.
    My hood separated already, but Im going to just let it flutter till I get a sport hood (sport hoods dont have the issue)
    Junkhead, Koolbreeze7 and tcjacado like this.
  5. Mar 6, 2021 at 2:09 PM
    dkamp
    dkamp [OP] Member
    Central Indiana
    Man you guys are Quick and Good!!
    I checked to Glue spots and all have separated. It seems to be a foamy like Silicon.
    I called the Dealer and they were already closed until Monday morning.
    Thank you guy a lot that's seems like an easy fix. :101010:
    if it is just Silicon should I do it myself?
    Junkhead, shakerhood and davidstacoma like this.
  6. Mar 6, 2021 at 2:11 PM
    tcjacado
    tcjacado Well-Known Member
    :anonymous:
    Superdave1.0, Junkhead and shakerhood like this.
  7. Mar 6, 2021 at 2:12 PM
    5nahalf
    Erik
    Minnesota
  8. Mar 6, 2021 at 2:14 PM
    5nahalf
    Erik
    Minnesota
    shakerhood and tcjacado like this.
  9. Mar 6, 2021 at 3:53 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Let them fix it, there could be rust that needs to be handled.
  10. Mar 6, 2021 at 4:28 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    It's pretty crazy that we're coming up on five years of production and this is still an issue
    Modesto Tacoma and Superdave1.0 like this.
  11. Mar 6, 2021 at 4:56 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    Just fixed mine this weekend using 3M NVH. I applied the NVH to the factory foam joints that failed as well as some other areas that could help with more contact adhesive between the hood skin and braces.
    There is lots of good info and pictures in the link posted in comment #8.
  12. Mar 10, 2021 at 6:43 PM
    dkamp
    dkamp [OP] Member
    Central Indiana
    Took my SR5 in to the Dealer today to get the hood glue joints fixed.
    They determined this was the first time that they have seen this condition. They have ordered the correct glue and will contact me when it arrives. They warned me that it is not a common part and it may take a few weeks to get the special glue. I asked if there would be a Loaner involved to allow the glue to set/dry. they told me that it only takes about 20-30 min so no loaner vehicle needed.
    Hmm:confused: I thought another thread someone mentioned it was a 24 Hr dry time. Well alrighty then.
  13. Mar 10, 2021 at 6:49 PM
    Bdbakel
    Bdbakel Well-Known Member
    Illinois
    '19 Sport DCSB 4X4 6MT Barcelona Red
    The other option is to swap out for a sport/scooped hood if you like the look of it and have the cash. The scoop actually keeps the two pieces secured together and eliminates the issue. Non-functional my ass!:rofl:
  14. Mar 10, 2021 at 6:52 PM
    chstaco
    SC
    2020 Tacoma
    Depends on what adhesive they are using. 3M NVH has a working time of 60 minutes and a cure time of 24 hours when ambient air temps are 73 degrees. (According to the spec sheet)
    I checked mine after a few hours and the adhesive was dry to touch but I figured why risk it and waited the full 24 hours before driving.
  15. Mar 10, 2021 at 6:58 PM
    BlackTRD4Me
    BlackTRD4Me Well-Known Member
    Sean
    2017 Toyota Tacoma Off Road
    Bull bar with lights, Wheels on stock tires, window vents.
    Mine's been doing it since I bought it, I didn't know it wasn't normal lol
    Tnc likes this.
  16. Mar 10, 2021 at 7:18 PM
    Clocktower
    Clocktower Recovering Jeep Owner
    Bangor, ME
    2019 Tacoma TRD OR DCSB / Auto 4X4
  17. Mar 10, 2021 at 7:21 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Some flutter is normal. But if you think the Taco is bad, try driving any given Ford an highway speeds!
    Adhesive separation definitely doesn't help that.
    BlackTRD4Me likes this.
  18. Mar 10, 2021 at 8:18 PM
    BlackTRD4Me
    Sean
    God yes!
  19. Mar 10, 2021 at 8:32 PM
    80grit
    80grit Active Member
    Jon
    Long Beach, CA
    21 OR DCSB
    Same here. I’m glad I saw this thread.
  20. Mar 11, 2021 at 8:54 AM
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Mine does it. Dealership fix is to replace hood but they come unpainted and your relying on the lowest bidding body shop to match and fade the paint on your new truck. F$&@ that!!! Fix it your self. Im going to try the 3M NVH stuff.
