[ R E C H E L O N ] 2 0 0 5 - 2 0 1 5 RETROFIT SOCAL GROUP BUY 6/3 - 6/20 [ A E S T H E T I C S ]
Discussion in 'RECHELON AESTHETICS' started by RECHELON, Jun 2, 2016.
  1. Jun 2, 2016 at 11:20 PM
    RECHELON
    RECHELON [OP] RETROFIT HEADLIGHTS
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    R E C H E L O N|AESTHETICS
    THE SOCAL RETROFIT GROUP BUY
    Our Passion is to Handcraft Custom Detailed Headlights
    Driven to Balance Aesthetics w/Performance
    [ STARTS MONDAY JUNE 6RD | ENDS WEDNESDAY JUNE 22ND ]
    1. SELECT BUILD STAGE
    2. INSTALLATION ( 2.5 HOURS ) + CLEAR SMOKE REFLECTOR
    or
    PASSIVE DEMON EYE & PROJECTOR BODY + CLEAR SMOKE REFLECTOR
    INSTALL | PICK UP LOCATION
    COSTA MESA OR SHERMAN OAKS
    HOW TO ORDER
    EMAIL US AT RECHELON.AESTHETICS@GMAIL.COM
    INCLUDE YOUR TW USER NAME
    INCLUDE THE STAGE # & ADDITIONAL OPTIONS
    We only use Parts from
    Toyota / The Retrofit Source / Diode Dynamics / Led Concepts
    * * DOES YOUR RETROFITTER PROPERLY LEVEL YOUR PROJECTORS? * *
    ALL LIGHTS ARE AIMED, LEVELED, & MOUNTED ON A STOCK TOYOTA TACOMA TO ENSURE ACCURACY. YOU'RE NOT BUYING A RETROFIT FOR JUST THE AESTHETICS. THE PERFORMANCE SHOULD BE THE MOST IMPORTANT OF THE BALANCE
    Follow us on Instagram at
    [ RECHELON.AESTHETICS ]
    BUILD STAGES
    [ 2005-2011 STAGE I $975]
    - Brand New OEM Genuine Toyota Headlights | Updated Clear Glass Version by Toyota
    - Aftermarket Headlight Price = $775
    - Brand New H1 7.0 Mini Projectors
    - Shroud Design of your Choice / Check The Retrofit Source's website@ (http://www.theretrofitsource.com/components/shrouds.html )
    - OEM TRD PRO BLACK SMOKE / CHROME FACTORY COLOR SCHEME
    or
    - Blacked Out Paint Work ( BEZEL / BOWL / SHROUD / DTRL BLINKERS )
    - You can request to leave certain parts of the headlight chrome
    - Smoke Amber Reflector ( Can Leave Stock Amber )
    - Brand New 35W Morimoto ballasts
    - Brand New XB Morimoto Bulbs (We Recommend 4500k or 5500k)
    - Brand New Morimoto H4 Wiring Harness
    [ 2012-2015 STAGE I $975 ]
    Aftermarket Headlight Price = $825
    - Shroud Design of your Choice / Check The Retrofit Source's website @ (http://www.theretrofitsource.com/components/shrouds.html )
    or
    [ 2005-2011 STAGE II $1055 ]
    - Brand New OEM Genuine Toyota Headlights * Updated Clear Glass Version by Toyota *
    Aftermarket Headlight Price = $855
    - Brand New FX-R 3" Projectors
    or
    [ 2012-2015 STAGE II $1055 ]
    Aftermarket Light Price = $905
    or
    [ 2005-2011 STAGE III $1295 ]
    - OEM NiSSAN MURANO / OEM ACURA TL PREMIUM PROJECTORS ( FINELY TUNED )
    or
    [ 2012-2015 STAGE III $1295 ]
    or
    [ ADDITIONAL OPTIONS FOR ALL STAGES ]
    - Passive Demon Eye / Subtle color accent inside the projector lens / Does not light up ( Color of your choice ) +$50
    - LED Demon Eye / Lights up inside the projector lens. (Color of your choice - Red, Blue, Green, Amber, or Purple) +$80
    - Halos (White or Amber / Front or Rear mounted) +$100 For One Set / +$180 For Both Front & Rear
    - RGB Color Changing Halos +$150 / +$270 For Both Front & Rear
    - RGB Color Changing LED Demon Eye +$150 ( Recommend to Wire them to a Switch/Button )
    +$270
    For Both RGB HALO & RGB LED DEMON EYE
    - Clear / Light Clear Smoke / Dark Clear Smoke Replacement Reflectors
    Replaces Stock Amber +$45
    - Black Chrome or Chrome Parking Light Corner +$30
    - Custom Color Matched Paint work / Our Professional Painter uses the best paint & clear product by GLASURIT. ( Pricing Varies )
    - Custom Art/Design Etching in Projector Lens +$45
    - OEM Upgraded Bulbs are Available to compliment your Choice of Projector (Pricing Varies)
    - 50W Ballasts instead of 35W +$10
    FAQ
    Q. Is there a warranty?
    A. Yes. We offer a six month warranty on workmanship. TRS components follow the TRS warranty period. For example, 5Five Ballasts carry a 24 month warranty. 3Five ballasts carry a 60 month warranty. Etc... No hassle warranty. Shipping cost will be taken care of by TRS for U.S. transactions. For owners outside the U.S., you will be responsible for the shipping cost per TRS.
    The cost of shipping the headlight(s) to to me is the original owner's responsibility. I will be responsible for the cost of returning the warrantied headlight(s) to the original owner within the U.S. Sorry, if you are outside the U.S., you pay shipping both ways. This warranty is NOT transferrable. Any modifications and/or tampering of headlights will void the warranty.
    Q. How hard is it to install the headlights and wire harness once I receive them?
    A. If you have a slight bit of mechanical skills, then the installation will not be difficult. The wire harness is plug 'n play, no splicing of the OEM harness is required (unless your lights are equipped with LED Angel Eyes). The new, retrofitted headlight bolts up the same way your old one was removed. Wire harness instructions are included with your shipped headlights as well as online.
    http://www.theretrofitsource.com/pdf/trs_tech/Bi-Xenon MotoControl Relay Harness.pdf
    The OEM headlight aiming mechanism remains fully functional. After your retrofitted headlights are installed, some fine tuning will be required utilizing the OEM adjusters. Fine tuning is defined as matching both the left and right cut-off so that they are level with each other. As a rule of thumb, I recommend aligning the height of the cut-off to be horizontal with the upper trunk line of the average sedan.
    Q. Where can I learn more about retrofitting, projectors and HID bulbs?
    A. The Retrofit Source (TRS) has a tremendous amount of online material to enhance your retrofitting knowledge.
    http://www.theretrofitsource.com/trs_tech.php
    Q. What's the difference between the bulb colors?
    A. Kelvin Ratings: 3000K - Has a golden yellow output perfect for use in fog lights. The yellow light penetrates through snow, rain, and fog more effectively than white or blue light. 4500K - Has a slightly off-white output similar to that of sunlight. Most cars that come equipped with HID headlights from the factory use 4300K bulbs. If you want the most usable light, 4500K is the Kelvin rating for you. 5500K - A pure white output, no tinge of yellow, and no tinge of blue. 6500K+ As you move into the higher kelvin ratings, your light output will appear more bluish-purple in hue, but the bulbs won't be physically as bright. I do not offer 6500k bulbs. As HID bulbs age, they go through what is known as "color-shift". When the bulbs are brand new, the output is whitish-yellow and as physically bright as it will ever be. As the bulbs age with use, their output turns more pure white/bluish and also starts to dim a bit. That's why cars with factory 4500K bulbs that are 5+ years old look like they're running 5500K or higher bulbs.
  2. Jun 2, 2016 at 11:23 PM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    HAVE YOUR OWN OEM HEADLIGHTS?
    WE CAN BUILD OFF OF THOSE AS WELL
    Contact us directly as we can work out the details
    RECHELON.AESTHETICS
    Questions/Inquries or Concerns
    rechelon.aesthetics@gmail.com
  3. Sep 21, 2016 at 9:54 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    @RAD Hey man, sent you an email. Still waiting on a response about the defective headlights I recieved from you and wanting to get the situation rectified. Let me know what's up.
  4. Oct 5, 2016 at 9:51 AM
    RAD
    RAD Well-Known Member Vendor
    Radford Candie
    Socal
    Sam, this is being worked on by Burt in resolving a solution. I know he built your OEM Murano projectors and tested the projectors when received them. Then tested them after they've been properly aligned and after the lights have been built. We will figure out a solution as Burt will contact you shortly in regards.
    Kind regards,
    RAD
  5. Oct 6, 2016 at 1:16 AM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Alright thanks. They are the TL projectors though.
