R155F transmission - Shifter housing and transfer case top access panel
Discussion in 'Technical Chat' started by andrew61987, Aug 25, 2021.
  1. Aug 25, 2021 at 10:43 AM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Is there supposed to be a gasket or RTV on the square shifter housing (4 bolts) that houses the shifter? There's already a sort of metal plate that goes in between the housing and transmission case. Not sure if there's supposed to be something more to prevent leaks.
  2. Aug 25, 2021 at 1:50 PM
    gearcruncher
    Canadain bumper technician
    Key-Rei and Dm93 like this.
  3. Aug 26, 2021 at 11:55 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Two paper gaskets on either side of that metal plate.
  4. Aug 27, 2021 at 12:15 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I just use the red transaxle FIPG on it on my R150F and now my RA60F, somewhere down the road I may get a RC62F and probably just use the red FIPG again.
    The red stuff has a higher resistance to the sulfurs (which should be low as the trans takes GLIV no GLV 75w90, I like Redline MT90) and other modifiers not found in engine oil that can eat the black FIPG.
    Note, Black FIPG skins in 15 mins, sets in 30 mins and is serviceable at this point then fully cures in about 2 hours, the red stuff takes 24hrs to fully cure and is not serviceable during this time.
    gearcruncher and 6 gearT444E like this.
  5. Aug 27, 2021 at 4:43 PM
    andrew61987
    I had Toyota 1281 FIPG leftover from the bearing retainer reseal so I used it on either side of the steel plates on both the shifter and T case access port. We'll see!
