Rack and Pinion Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jim Mann, Mar 8, 2007.
  1. Mar 8, 2007 at 9:30 PM
    Jim Mann
    Jim Mann [OP] Well-Known Member
    The service facility where I take my 96 Tacoma 4WD EXT Cab says that my rack and pinion has worn out bushings, and that the whole thing has to be replaced. I do trust these guys, they are some of my customers, and have known them for a few dollars. They have done excellent work on several other vehicles, as well as this truck. Have any of you had to replace this before? 160,000 miles is not a lot, however, the truck is worth fixing and keeping. I have too much in it to bail out now. Jim
  2. Mar 9, 2007 at 4:31 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    get someone else to look at it also
  3. Mar 9, 2007 at 8:31 AM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    a second opinion won't hurt, just don't let them know.
  4. Mar 9, 2007 at 4:55 PM
    yotaman502
    yotaman502 Well-Known Member
    New bern, NC
    Does the steering have loose play in it. After 160K miles, they probably are worn.
  5. Mar 9, 2007 at 7:39 PM
    Jim Mann
    Second opinion confirms, worn out bushings. The truck wanders on the road, constant correction required. Nothing major yet, but this has been going on for a month now and is getting worse. They will operate on Monday
  6. May 11, 2007 at 6:32 AM
    abu-guru
    abu-guru Member
    You can just replace the bushings. Senergy/energy? Makes a bushing kit for $20.00 My 03 Taco has a loose bushing already:mad:
  7. May 12, 2007 at 4:00 AM
    BrianPK
    BrianPK Offroad Enthusiast
    Modesto, California
    01 TRD 4WD V6 SR5
    CB Radio, 3'' fabtec spacer lift and 3'' body lift flowmaster dual exhaust, deckplate mod, silencer mod, Work in progress pioneer 7900bt stereo with 5X8 infinity speakers all around, and eclipse ex400 amp
    i have this same problem... the dealership i bought the truck from said i had worn out bushings and something about a reman-link...
    519 dollar part
    anyone know where i can get the entire kit for cheaper?
  8. May 12, 2007 at 5:20 AM
    abu-guru
    abu-guru Member
    Energy suspension makes them as well as new bushings for the link arm. The dealers are a joke and just want to replace the entire rack.
    Mine are wore with only 44000 mi and this is a common problem. It's time to start complaining to toyota and the BBB and demand a recall.
  9. Jun 27, 2007 at 8:14 PM
    Rico
    Rico Member
    I have a 2000 Tacoma w/ 4WD and my bushings are definitely worn out. I suspended one wheel in the air and was able to move the wheel from left to right with to much play. You can actually see the entire rack pinion move. The main rubber Grommet and the rubber bushings are very loose and cracking. The problem I have is ONLY when I apply brakes while driving at speeds over 30 MPH then the front and starts shacking violently.
    I hope the energy suspension parts fix the problem.
  10. Jun 28, 2007 at 3:52 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    the energy bushing are way better than oem. rubber = poop, polyurethane = awesome.
  11. Jun 28, 2007 at 4:03 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  12. Jun 28, 2007 at 4:59 PM
    Rico
    Rico Member
    Huminoid...Thanks for the links man! You just made life so much easer for me. Know I should be able to fix this in about an hour or two while sipping on a beer:D
  13. Jun 28, 2007 at 5:00 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Glad I could help!
  14. Jun 28, 2007 at 5:04 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Forgot to add that since you're down there, you should replace the sway bar bushings as well, you too can purchase those from Wheeler's (and no I don't work for them or get any compensation from them).
  15. Jul 24, 2007 at 4:52 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have an 2004 and I had the same problem. I had a 1995 and there was a recall back in the day. I think it covered all tacomas 1995 to 2004 but you know how it goes they ran my vin and said mine wasent covered so I had to have the bushings replaced at 36,000 miles I think the rack and pinion just is weak I know for a fact the whole system is like 1,400 to replace so fix the bushings before it gets bad and you have to replace it all..
  16. Apr 19, 2010 at 8:29 PM
    TacomaTank
    TacomaTank New Member
    New Britain
    95 Tacoma V6 SX
    I'm pretty late in posting a reply to this, so sorry. I am a new member and have purchased a used 95 Reg Cab Tacoma about 7 months ago. I also experienced the violent shaking when applying my brakes and noticed the rack moving when moving my tire from left to right while it was suspended. This thread was very helpful so thank you all for contributing. I do have some questions though if someone doesn't mind answering?
    First, I am have bad inner tire wear. Could this be from the worn out bushing? Secondly, can some explain what the link arm is?
    Thanks
  17. Apr 19, 2010 at 9:40 PM
    adiablo420
    adiablo420 Active Member
    HI DESERT CALIFORNIA
    96 TACOMA 4X4 4 CYL
    SUSPENSION LIFT, RIMS AND BFG MUD TERRAINS
    i had that problem ...outer tie rod ends....
  18. Oct 20, 2012 at 4:55 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I ordered the parts and had a local 4x4 specialty shop install the R&P. I did inner and outer tie rods (moog) with energy sus bushings.
    Feels great and no more wobble. Plus, no inner tire wear (cause by bad tie rod)
  19. Oct 21, 2012 at 8:33 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Yup, do the bushings first, then outer/inner tie rods...
    I've done all and i still wander/have play, i only have 125k miles on it. FWIW, my tie rods were shot and needed to be replaced anyway.
    Not looking forward to buying a new rack, they're a PITA to install. We tried on a friends 98 ext. Couldn't get the effer out.
  20. Oct 24, 2012 at 9:14 AM
    dragonfire
    dragonfire New Member
    gary
    louisiana
    96 tacoma dx 4x4 excab 260000 k. 2.7
    Did my own suspention my own fabrications
    So are mine if you. If you look at it you can change just t. Well you can on mine. If we tlkn bout same e bushings
