Rack bushing question
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMX, Jan 31, 2012.
  1. Jan 31, 2012 at 12:18 PM
    TacoMX
    TacoMX [OP] TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I am about to order a new (re-manufactured) rack and pinion and need new rack bushings too.
    I am confused about one thing. I noticed that 95-00 bushings and 01-04 bushings are slightly different. Are these differences in the rack or the frame mounts?
    I was going to order a Prothane 95-00 kit, but dont want there to be any compatibly problems if the rack I am ordering came off a newer taco.
  2. Jan 31, 2012 at 1:51 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Just to be safe you can just buy the wheelers kit. It has an extra piece for that.
    EDIT: and i am prety sure the difference is the bolt diameter
  3. Jan 31, 2012 at 4:36 PM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    OME Nitrocharger OME Dakars All the other small goodies
    I just installed the wheelers last weekend... You will still have a little slack just an fyi..
  4. Jan 31, 2012 at 4:46 PM
    TacoMX
    Jonathan
    Deltona, Florida
    right, but the prothane 95-00 kit is specific for the 95-00 just like the Wheelers/Energy suspension kit.
    bump for any more insight...
  5. Feb 1, 2012 at 4:51 PM
    classic42
    classic42 Well-Known Member
    14 Baja AC
    The extra piece that is in the Wheeler's kit is a 9/16 sleeve for one of the bolts. If you're using the same bolts, I would think the 95-00 kit would be what you need.
  6. Feb 12, 2012 at 10:10 AM
    TacoMX
    Jonathan
    Deltona, Florida
    I figured I would update this: I just got the bolts out of the old rack, and the prothane 95-00 kit does indeed have the correct Inner diameter bushing sleeves for the 95-00.
  7. Feb 12, 2012 at 11:14 AM
    classic42
    14 Baja AC
    :thumbsup:
