Rack & Pinion problem?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco05, Apr 16, 2012.
  1. May 15, 2012 at 11:27 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Normal. Both my buddies truck and mine do that when the engine is off. It should not be present once the engine is running and the power steering system is pressurized.
  2. May 15, 2012 at 11:33 PM
    pinktaco05
    pinktaco05 [OP] Active Member
    NE Nevada
    05 Silver TRD Debadged
    Kenwood DNX6980,5100's, Eibach's, All Pro Expo's, Timbren's, Toyo MT 285/75/16, K&N FIPK, Magnaflow, URD short shifter, Westin grille guard
    Yes, it did seem to drift where it pleased. It stopped doing that, my steering wheel stayed straight, but now it seems to stay to the right during right turns. It's not hard to bring back, but you still have to bring it back.....I am not sure if that is going to fix your steering or not.
    10-4. Tomorrow I will crank the piss out of them and see what we come up with! Thank you for all of your help so far.
  3. May 15, 2012 at 11:58 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Hmm. Wouldn't happen to have a copy or your alignment sheet would you? If you lower control arms alignment cams are loose they may have moved and upset your alignment specs. Steering that is random and doesn't return to center is either due to low caster, or loose steering components.
  4. May 16, 2012 at 8:12 PM
    pinktaco05
    NE Nevada
    Well....the tire shop couldn't find my leak, and they told me that the noise is my tires hitting my bumper. Spray painted, no rub marks. Trimmed more just to be safe. Still noise. Took my grille guard off...still noise. Tightened up my lca's, got the 2 rears on each side a little bit tighter.Guess what....still have the noise. Jacked my truck up, no wiggle either way on the tires. When I spun them by hand I could hear a little noise, I am assuming normal brake noise? So, what is plan B?!?
  5. May 16, 2012 at 10:34 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Plan B is:
    Does it look or sound anything like this > http://www.youtube.com/watch?feature=player_embedded&v=z4lduZmPABo
    If not, how reproduceable is the symptom. Can you make the noise on command?
    SuazoYota, Kolter45 and dfire451 like this.
  6. May 16, 2012 at 10:52 PM
    pinktaco05
    NE Nevada
    They don't seem to move like that, at least what I can see from looking and having the wife move the wheel. I can not replicate the sound unless I drive over certain stretches of road. Or going down the SLIGHT hill at my house in 1st gear, it makes a noise. Not the clunking like over dips, but more of a binding metal sound. At one point today I thought I had it pretty much whipped, but after going over several speed bumps it came back. Kind of like something shifted and started the noise again. Not sure WTF it could be. I have torqued everything down several times.
    I did notice that there was some leaking on my right axle, where it's blocky, before it goes to the shaft. The noise is coming from the left though, where I can grab the shaft and jerk it passenger to driver and get a little movement.
    Ball joints & wheel bearings have never been replaced.
    Brake pads(recently) steering rack & outer tie rods(recently) and cv's (2 years) have been replaced.
  7. May 17, 2012 at 12:01 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    I have the clunk in my front suspension check to see if your lower ball point boot are ripped if so, i would say spray wd40 in the ball joint, and then spray the LCA bushings. I know my lower ball joints are shot, and the lca bushings are shot too. I replaced one tie rod, there pretty easy to replace but a pain to just take off without spinning the tie rod. I would say our ball joints and LCA bushings are shot. Even if you crank the shit out of the LCA's there still play. Get under your truck and have someone crank the wheel left to right, and back. You'll hear it.
  8. May 17, 2012 at 5:40 PM
    pinktaco05
    NE Nevada
    05sctaco - does your truck make it only over bumps? Or does it do it while turning at slight inclines as well like mine?
  9. May 18, 2012 at 6:32 PM
    pinktaco05
    NE Nevada
    It is now making noise backing straight out of my garage......little help.
  10. May 18, 2012 at 11:39 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Well seeing as you can reproduce the sound backing out of your garage... How's about a video clip for us to see and hear. You should definitely be able to get under there and see/feel/listen for the exact location.
  11. May 21, 2012 at 6:20 PM
    pinktaco05
    NE Nevada
    Finally took it to my real mechanic. Not sure why I didn't do this sooner. He said my motor mount is failing, causing the fan to hit the shroud. I took it to the dealer to see what they say. Work will start tomorrow. If not, my mechanic will fix it up.
  12. May 21, 2012 at 6:22 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    :facepalm: Can't believe I forgot that it could be the motor-mounts. Its actually kinda common
  13. May 21, 2012 at 6:29 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Did they change the motor mounts after 05'? I know my 08' has more gusseting beneath the mounts than early models. Is that the only place where they fail?
  14. May 21, 2012 at 6:31 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    What a relief to know what the problem is. Too bad it's not a quick fix.
  15. May 21, 2012 at 6:38 PM
    #35
    pinktaco05
    NE Nevada
  16. Jul 2, 2012 at 5:25 PM
    #36
    kaell00taco
    kaell00taco New Member
    Kelly
    Happy Valley, OR
    2000 4X4 SR5 Tacoma
    6.5" Fabtech lift, K&N air, Flowmaster exhaust
    I have the exact same problem and metal clunking noise in my truck (turning, bumps in the road, and backing up) but I have a lot of play in my steering. Also when I go around slight corners mines more of a grinding noise, and my steering also doesn't return straight by itself. I read the entire thread, but what was the final fix for this? I replaced all four ball joints and my shocks but have yet to tighten the bolts underneath, which I'm going to do today.
  17. Jan 31, 2020 at 5:52 PM
    #37
    dfire451
    dfire451 Well-Known Member
    Hawthorne, CA
    2008 Black Tacoma Prerunner trd sport dclb
    Kings2.5 front and rear with adjusters spc lr uca scs ray 10 17x8.5 bfg ko2 285/70/17 c load icont rxt springs
    Kolter45 likes this.
  18. Feb 24, 2021 at 7:13 AM
    #38
    garrett2eat
    garrett2eat New Member
    Garrett
    2007 Red Tacoma TRDOR
    @rzimm001 i get that same metal popping noise from your video when reversing and turning out of a parking spot. Did you figure out the problem? LCA Bushings?
  19. Feb 24, 2021 at 5:03 PM
    #39
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Yes it ended up being the lower control arm bushing. The a-arm was stretched from too much wheeling I guess. New a-arm fixed it. I tried a new bushing but it’s a pressed fit.
