radiantor fluid pink?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by linkfeeney, Mar 8, 2009.
  1. Mar 8, 2009 at 8:52 AM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    I notice the truck's radiator fluid is pink?
    they are always greenish/blue... where can i get pink? last time I was at the auto store, I sure dont see pink fluid? and what u guys suggest to fluid and fill?
    thanks!
  2. Mar 8, 2009 at 8:53 AM
    tjgraner09
    tjgraner09 South Carolina Member
    TJ
    Conway, SC
    97 XtraCab
    Bilstiein 5100 w/ TRD Coils in the front, new fog lights, 2 12" isignia subs,
    I got mine at the toyota dealership
  3. Mar 8, 2009 at 8:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think you can only get it at the dealer. I thought it was the same stuff as the GM's used (red/orange), and was readilly available, but I had someone tell me its different, and cant be mixed with the GM stuff.
  4. Mar 8, 2009 at 10:27 AM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
    The Prestone Long Life will work fine and it is for all makes. No problem. Don't waste money at Toyota.
  5. Mar 8, 2009 at 11:00 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Radiator fluids are not like engine oils that are mostly compatible, many times you won't have a good outcome if you start mixing radiator fluids.
    I just go to the dealer and get the pink stuff, especially since that's something that I don't change very often. I think Toyota says every 100k or so you should change it. Personally, I drain and refill the fluid every 30k or so, easy to do and I sleep better :D
  6. Mar 8, 2009 at 11:06 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    I just flushed mine and put the green stuff in..no problems so far. Thats also what was in there when I got the truck..Havent had a problem yet.
  7. Mar 8, 2009 at 11:21 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    well, does the pink turns in to black or gray? because the green/blue will turn to greyish crap with you dont change it in a while.
  8. Mar 8, 2009 at 11:22 AM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    not that I know of..pink stays pink..Maybe turns to a red?
  9. Mar 10, 2009 at 2:33 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    The pink kinds are the 'long life' fluids. My bf works at GM as a Service Tech, he says they use the same stuff in the GM's/Chevy's, according to him they are not worth the extra $$ and wouldn't suggest waiting till 100k to change it. But he said it is not compatible with the regular green antifreeze so you have to make sure to throughly flush all the pink fluid out to replace it. I was just asking him about it a couple weeks ago when I was doing the 20k on my truck.
    I see a jug of Toyota-Scion Long-Life Antifreeze/Coolant on Ebay for $19.75 (I can't post a link cause ebay is blocked at work).
    "Peak Long Life" states mixes with any color antifreeze.
    http://www.buyhardwaresupplies.com/?t=5&m=g1&itemNumber=8208225
  10. Mar 10, 2009 at 4:36 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i might just stick with the pink, the manual does not say anything about the when to change it... I guess I'll do it at 50k... what do u guys think?
  11. Mar 10, 2009 at 4:39 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Coolant fluid is pink. If so, Its Toyotas "Super Life" coolant. They say you can go 75,000 to 100,000 miles on that coolant because it recycles itself.
    if you do change it then go with the Toyota Super Life again or Prestone 50/50
  12. Mar 10, 2009 at 4:46 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I have am currently running the Prestone 50/50 mix. I have no issues with it. In about 50k I think I will go back with what the dealership offers.
