Radiator Coolant Flush vs Drain and Refill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Oct 20, 2017.
  1. Oct 20, 2017 at 10:36 AM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Has anyone done a coolant flush as opposed to just draining and refill? I've heard some of the flush maintenance can be damaging or unnecessary. Thanks for your advice!!
    Rambo54 and ChadsPride like this.
  2. Oct 20, 2017 at 2:53 PM
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
    I have done just the drain and refill using Toyota 50/50 premix, if your coolant system is good and just want to freshen up the coolant, I do not see any problem with it. Now, If it was an older system with old unknown fluid, I would flush with distilled water, and then put in new Toyota 50/50 fluid.
    Flush it using gallon jugs of distilled water, depending how bad the old fluid is, remove thermostat, drains, etc until it flushes clear water. I freshened up my 09 V6 at 100K.
    Rambo54 likes this.
  3. Oct 20, 2017 at 8:57 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yes, flushed at 140K. No issues. Used Wallyworld's SuperTech, a universal coolant. No need to use corporate coolant. Also replaced hoses, belt, and thermostat.
    Are you concerned new coolant could dislodge crud and plug the radiator? It's a valid concern if your cooling system has been neglected to that level. However, it's worse not replacing old coolant which will be lacking anti-corrosion and lubricating properties; neglected coolant will likely lead to cooling problems down the road.
  4. Nov 2, 2017 at 8:42 AM
    2009Access4x4
    Shane
    No, I was concerned about using a flushing machine that some have said is not good for your vehicle. I ended up having it drained at a valvoline place. They used non toyota standard coolant and didn't take out all of the old coolant. I took it to a local mechanic who has worked on many toyota and he said that the toyota coolant is crucial because the additives are designed specifically for toyotas. he said he has had to fix many hoses because people use other coolant. Anyways, no way for me to know other than to take advice from others.
  5. Nov 2, 2017 at 8:48 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    For systems where the condition is unknown I like to use a distilled vinegar flush (or citric acid + dIH2O) as it helps dissolve some of the scale distilled water misses. The Toyota LL coolant is also acidic but it just keeps the scale in suspension - flushing with a weakly acidic solution prior to coolant gets it out of there.
  6. Nov 2, 2017 at 4:43 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    How strong a vinegar solution do you recommend? TIA.
  7. Nov 2, 2017 at 8:02 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I wonder if you are confusing a coolant flush with a transmission fluid flush?
  8. Nov 2, 2017 at 8:15 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    I was wondering when this service should be done? Mine is still nice and pinkish and I never really saw a need to do this but lately I feel like I've reached 65k miles and may have to drain out the original coolant and put in some fresh stuff.
  9. Nov 2, 2017 at 8:23 PM
    Lester Lugnut
    For me, it's not just about mileage, but time. I change coolant - radiator/block/overflow bottle at least every 3 yrs. regardless of mileage. I think Toyota's plan is 100K miles - 5 years.
    My fluid/filter intervals occur more often than what the book calls for because I drive vehicles for 15-20 years.
    Taco-Obsessed and bogginator like this.
  10. Nov 3, 2017 at 5:21 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What do you do with the old coolant you flush out? I know you can bring retired oil to an auto parts store for recycling but what do you do with coolant?
  11. Nov 3, 2017 at 6:50 AM
    Lester Lugnut
    In my area O'Reilley's accepts all kinds of fluids.
  12. Nov 3, 2017 at 7:08 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    In my area there is a household toxic roundup once a month in rotating cities within the county or you can take it to the household toxic facility on weekends.
    If your city/county publishes a recycling guide check there.
  13. Nov 3, 2017 at 12:28 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I say phooey on the the Toyota coolant. Toyota specifies a P-HOAT (phosphate hybrid organic acid technology) type coolant for current models, back to mid 1990's. Specifically, a coolant with phosphate but no silicates, borates, 2-EHA, or nitrites - I might be missing a chemical there. The purpose of these chemicals is to protect the metals in the cooling system and inhibit corrosion.
    Universal coolants are formulated to be compatible with a wide range of coolant systems. It's OK to trust the label of a reputable coolant manufacturer if they say their coolant is compatible with your vehicle - they wouldn't be in business if their product was snake oil. At 90K, I switched to a universal coolant (Prestone, I think) in our 98 Toyota Sienna. At 230K I had the water pump replaced as preventive maintenance - van has never had cooling issues. All my other Toyota products have SuperTech universal coolant. The important thing is to flush out the old stuff as much as possible. And to replace the coolant timely, as @Lester Lugnut points out above. Follow the manufacturer's instructions and you will not go wrong.
    Using a flushing machine is OK. I think the issue is with neglected cooling systems where the flow of coolant caused by a flushing machine can dislodge matter that can get trapped in the water pump or thermostat. If the material is not flushed out completely, it acts as sandpaper as it flows through the coolant system, negating the anti corrosion properties of coolant.
    http://www.aa1car.com/library/2004/us120426.htm
    http://www.machinerylubrication.com/Read/841/coolant-fundamentals
    http://www.engine-performance-onlin...l-antifreeze/engine-coolant-antifreeze-types/
    koditten likes this.
  14. Nov 3, 2017 at 12:30 PM
    Oreo Cat
    Oreo Cat Worst Member
  15. Feb 14, 2018 at 4:40 PM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    I disagree with removing the thermostat. If you do remove the thermostat, there's now no resistance in the cooling system. So all the muck and trash that sat in the bottom of the block breaks loose and floats up to the radiator clogging it!
  16. Feb 14, 2018 at 4:49 PM
    Plain Jane Taco
    Plain Jane Taco ALL human beings deserve equal treatment
    USA
    Valvoline with Zerex. Meets all the requirements for both Toyota LLC and SLLC coolant and is red/pink in color. Not only is it a good replacement for the OE coolant, but it's also compatible with it.
    Prediluted and ready to use.
    $12 a gallon at Walmart. All the local stores in my area stock it.
    birry, tacoman45, KTM753 and 2 others like this.
  17. Feb 14, 2018 at 5:25 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I just did my engine coolant this past weekend at 150k miles. I had done one radiator drain previously.
    This time I Drained the radiator and the two engine block drains. Replaced with Pentofrost A4 coolant, it is pre mixed.
  18. Feb 14, 2018 at 6:00 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Kinda funny they have Hyundai/Kia listed on there, when those come with green coolant from the factory.
    I’ll give another thumbs up to Pentosin A4, you can buy it at Advance or Autozone.
  19. Feb 14, 2018 at 6:05 PM
    billybob50
    Bob
    It's antifreeze! They want you to think it's very special, only buy their expensive stuff. So now they got you thinking really hard cause it's a different F-----g color. I use walmart antifreeze without any issues!
    Lester Lugnut and Chuy like this.
  20. Feb 14, 2018 at 6:26 PM
    Plain Jane Taco
    USA
    The Zerex formula comes in different colors to mimic the OE colors...red for Toyota and blue for Honda and some of the European makes.
    They list Honda and Hyundai/Kia on the red formula because they require a silicate free HOAT formula with phosphate, just like Toyotas do. Despite its red color it is compatible with Hyundai and Honda's OE fluid. You could use the blue formula in them too....including Toyotas.
    BTW, not all green coolant is the same. Your basic green coolant is not the same as Hyundai/KIA's green coolant.
    What ever coolant you decide to use, you're better off in the long run to go with a silicate free HOAT formula with a phosphate additive. Unless it specifically says that on the container....it is not.
    tacoman45 and Lester Lugnut like this.
