Radiator Coolant Flush vs Drain and Refill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Oct 20, 2017.
  1. Aug 8, 2022 at 12:29 PM
    #41
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Try the NAPA version. Mine fits snug as a bug.
    TnShooter likes this.
  2. Aug 8, 2022 at 1:12 PM
    #42
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mine didn’t fit too good either.
    But it fit tight enough not to leak.
    The adapters are cheap stamped steel.
    I can’t say I’d recommend Lisle.
    I’d probably recommend a different brand.
  3. Aug 8, 2022 at 5:20 PM
    #43
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    Went ahead and did a drain and refill. Drained the radiator then the passenger block and then the drivers block. More coolant came out of the passener side block then the drivers. Don't understand why but I moved on. Refilled with prestone red asian vehicle coolant. Burp it. Nothing is leaking. However, seems that it is getting hotter quicker then before. It doesn't overheat at all though. It took just over 10 quarts to fill.
    tacoman45 likes this.
  4. Aug 9, 2022 at 5:44 PM
    #44
    tacoman45
    Orygun
    Sounds like you got most of it at 10 qts. I’m assuming your motor stays at operating temp?
  5. Aug 10, 2022 at 4:34 PM
    #45
    bear263
    Florida
    Yep. Stays at temp. Fan doesn't run either. Again, just seems it gets hotter faster. Maybe difference in coolant.
  6. Aug 10, 2022 at 4:44 PM
    #46
    soggyBottom
    soggyBottom Well-Known Member
    I graduated high school almost 20 years ago. While there, I had an auto tech class that was by no means compatible to your work experience. That said, I recall them teaching that part of a flush was to run it backwards to help remove deposits. Since you have seen problems first hand, I will take your word over mine.
    Out of curiosity, what kind of problems have you seen with revered flow?
