Radiator Flush
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, May 8, 2016.
  1. May 8, 2016 at 4:16 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Anyone have any links to any good tutorials out there on how to do a coolant flush on a first gen 2.7L?
  2. May 8, 2016 at 8:45 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Check the stickies....
  3. May 8, 2016 at 9:06 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    1. Drain your radiator
    2. Fill up with distilled water
    3. Turn on heater and drive for a bit.
    4. Let cool, and repeat until clean, clear water is all you get. Usually a 2-3 times.
    4. Drain radiator and fill with coolant of your choice. I took into account the water in the engine and heater core and mixed my full strength coolant 60/40 with distilled water for a 50/50 final mixture.
  4. May 8, 2016 at 10:52 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Y
    Yep. If you want to go a step further you can get one of these http://www.amazon.com/Prestone-AF-1...1462729894&sr=8-2&keywords=coolant+hydrometer to see approximately where your coolant is chemically.
  5. May 8, 2016 at 11:03 AM
    TACO TX
    Kelly
    Denison ,Texas
    I have one, my final mixture was good to 10 degrees which is plenty here in Tx.
  6. May 11, 2016 at 5:05 AM
    goldentaco03
    Liam
    NJ
    My coolant is good still but my upper and lower hoses are bad so I am just gonna do a whole flush. Question with the flush. Is there any way to get all the cleaner/water out of the system so I can just put 50/50 in??
  7. May 11, 2016 at 5:10 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    There's probably not much water left once you drain it, and just filling with 50/50 will get you close enough.
  8. May 11, 2016 at 5:17 AM
    goldentaco03
    Liam
    NJ
    Got it thanks.
  9. May 11, 2016 at 5:55 AM
    TACO TX
    Kelly
    Denison ,Texas
    Depends what coolant you plan to put back in, I used Toyota red which comes full strength and had to mix myself. I wouldn't use anything else personally.
  10. May 11, 2016 at 8:45 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Not sure what the 1st gens came with standard, but the 2nd gen is the Toyota pink (not red). It comes in a 50/50 mix.
  11. May 11, 2016 at 9:45 AM
    TACO TX
    Kelly
    Denison ,Texas
    1st gen is red and come full strength, not 50/50 like the pink.
  12. May 11, 2016 at 9:56 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    The pink and red are slightly different formulas. Diluting red does not turn it into pink (well, it may look pink). But either should work fine.
  13. May 11, 2016 at 11:01 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    The first time I flushed I used Toyota Red, $40 a gallon, fuck that's that just ridiculous... so the last time I refilled from the radiator change I used some Prestone.
  14. May 11, 2016 at 1:25 PM
    goldentaco03
    Liam
    NJ
    Yeah I'm going with the prestone pre-diluted... it's only like $8 a gallon
  15. May 11, 2016 at 1:55 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Should be fine as long as it gets a good flush. Just don't mix the green with the pink.
