Radiator Replacing fan with Electric Fan
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Jun 26, 2010.
  1. Jun 26, 2010 at 6:54 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  2. Jun 27, 2010 at 1:53 AM
    Got Taco?
    Got Taco? 1st Gen Taco
    Arizona
    1st Gen
    1998 Taco: RevTek F/R lift JBA cat back MagnaFlow cat K&N CAI Tundra 13WL brake conversion Redline hood struts Flex-A-Lite dual radiator fan Galaxy DX979 (barefoot), Wilson 1000 (thru-roof). 2012 - Finally "Bro-Lean" status since springs have negative arch. =( Current vehicles as of 2022: 1971 - Honda CT70 1976 - Puch N RIGID 1998 - Tacoma PreRunner (daily driver) 2001 - Lexus IS300 2002 - Lexus SC430 2002 - Lexus LS430 Ultra Luxury 2003 - Lexus GS430 2004 - Lexus LX470 (overland project)
    I installed it in May (with pics from my post) and I'm on my 6th full tank of gas since install. More throttle response especially freeway speeds, better mpg... sorry no numbers only the fact that I fill up less often with my tank taking me farther. Simple straight forward and I think it was about 2 hours for install but that number may be less since I also replaced my radiator and thermostat too. Worth the money.
  3. Jun 27, 2010 at 3:56 AM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    I been wanting to do this, suppose it couldn't hurt on a 2nd gen too :notsure:
  4. Jun 28, 2010 at 10:00 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Awsome, thanks for the pics! That fan is pretty dam'ed expensive! How was the difficulty level for the install? Any mods you had to do or was it a simple bolt on. Also, how did you adjust the temp thresh holds for the fan (or do they come pre-adjusted)?
  5. Jun 28, 2010 at 11:17 AM
    Got Taco?
    Arizona
    1st Gen
    Installation is simple. One thing that may be different from my install is that I had the radiator removed which gave me more space to work with. Shouldn't make that much difference. As for the adjustable thermostat........ I tinkered with it a few times and found that it works just fine dead center. Since the probe for the thermostat needs to be within the specified 18 inches of the radiator, I mounted my thermostat control box onto the heat shield of my CAI since the firewall would have placed it further than 18 inches. Other than that, I like the fact that replacement parts are available for this fan. Hope this is of some help.
  6. Nov 10, 2010 at 10:41 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    i'm looking at doing this too, i emailed Sam with a couple questions on the wiring and controls
    Got Taco? - which kit did you get? looks like you have the aluminum brackets vs the plastic ones
  7. Nov 14, 2010 at 1:32 AM
    Got Taco?
    Arizona
    1st Gen
    I have the Flex-a-lite 675. It came with the double aluminum brackets.
  8. Nov 14, 2010 at 6:37 AM
    JDBECK23
    JDBECK23 Well-Known Member
    Jesse
    King George, Va
    '01 Tacoma Reg Cab 4 cyl 4x4
    sorry to thread hijack, but Got Taco's not receiving PMs.... What step bars are those Got Taco??
  9. Nov 14, 2010 at 3:54 PM
    vantaco
    how do you find the thermostate and the themp sensor?
  10. Nov 14, 2010 at 4:44 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I'm currently piecing together a Ford Mark 8/ Thunder bird 2 speed fan swap. Got the fan already just need the Relay from "The Hollister Road Company." And I'm debating on making a custom aluminum shroud or just use the stock plastic one and cut the ford fan up to fitting.
  11. Nov 14, 2010 at 6:48 PM
    Got Taco?
    Arizona
    1st Gen
    They're SmittyBuilt.
  12. Nov 14, 2010 at 6:49 PM
    Got Taco?
    Arizona
    1st Gen
    The thermostat controller and the temp probe came with the fan as a complete kit from Summit Racing when I ordered it.
