Radio Bolt - Stripped
Discussion in 'Audio & Video' started by Kenobe, Nov 18, 2012.
  1. Nov 18, 2012 at 12:00 PM
    Kenobe
    Kenobe [OP] Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    Hey guys, well I fooked up. I took my radio out to ground out the wire that lets you watch videos while driving (new Pioneer system). I went to put it all back together and put in the 4 bolts that hold the radio bracket in the dash.
    I derped and cranked one of the bolts too hard, stripping whatever it holds in to inside the dash. I tried backing it out, even with a pair of vise grips and pulling back while trying to unscrew it to no avail.
    So, am I stuck with cutting into the dash to try and get this bolt out?
    Ken - idiot who tightens things too much.
  2. Nov 18, 2012 at 12:46 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    your not alone ken, i will see your stripped bolt and raise you one broken in half.
    torqued it too much as well, bolt snapped, the bottom half is still left in the lower dash mount argh!
  3. Nov 18, 2012 at 1:14 PM
    Kenobe
    Ken
    09 Tacoma TRD Sport
    d'oh!
  4. Nov 26, 2012 at 9:13 AM
    Kenobe
    Ken
    09 Tacoma TRD Sport
    So I took the dash further apart and found the problem.
    The nuts which hold the 4 stereo bolts are welded into a c-type metal clamp. That is clamped onto the plastic holders which appear to be an integral part of the overall dash. That plastic is EASY to break. if I'm looking at it right you would have to replace the whole dash in order to replace those broken bits of plastic. I have another idea in mind but it will be a while before I feel like tearing into the dash again.
