Radio defective in new 2021? Worst noise on calls, buzzing, etc
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cwilliams, Nov 20, 2021.
  1. Feb 15, 2023 at 8:26 PM
    #61
    Waterloo Wonder
    Waterloo Wonder Waterloo Wonder -
    Forrest
    New Hampshire
    21 Access Cab - Army Green,
    I will restate from the above post. When on a blue tooth call adjust the transmit volume to the lowest setting. It eliminates the buzz. It worked for my truck and my brother's
    Canadian Caber likes this.
  2. Feb 15, 2023 at 8:41 PM
    #62
    CriusTitan
    CriusTitan Well-Known Member
    2023 TRD Offroad DCLB Icecap
    That only works for Bluetooth not CarPlay
  3. Feb 17, 2023 at 8:50 PM
    #63
    CriusTitan
    Update, unplugged SOS didn’t work so it’s not that signal getting mixed up. Also took it in for servicing second time for it and they pulled another 2023 off the lot that had the same issue with buzzing and said they can’t fix it since it’s a “normal” occurrence of other trucks in the same year. To me that signifies there’s something wrong in this years build. Calling corporate next week. Will check back in.
    TRDTaco4WD likes this.
  4. Feb 18, 2023 at 2:55 PM
    #64
    CriusTitan
    When you say turn off, do you mean cancel the subscription or just have it off on the head unit settings? Mines off in the head unit but still buzzes while vehicle is running.
  5. Feb 21, 2023 at 3:48 PM
    #65
    CriusTitan
    Can anyone with issues verify the software version they are on. Mine is running 1792, the update release in 2022 is 1790, wondering if i should try to install the previous version
  6. Apr 9, 2023 at 7:47 AM
    #66
    23taco
    23taco Member
    My truck is doing the same thing it's a 2023 trd off road . I lowered the transmit volume and it greatly reduced the noise in bluetooth but CarPlay is still an issue. Dealer tried to blame my phone its an iphone14. BS ! Interesting when i was doing my own troubleshooting the problem only occurs when the ignition is on regardless of whether the engine is running and does not occur in accessory mode. with leads me to believe it is being caused by electrical interference.
  7. Apr 9, 2023 at 8:23 AM
    #67
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    2021 SR5, no issue at all, works great via Bluetooth or Carplay. I have no other services connected ( SOS etc ).
  8. Apr 9, 2023 at 11:39 AM
    #68
    CriusTitan
    Yup that’s the exact issue I have. Some kind of electrical interference with the engine. No resolution for me so far corporate and dealership said it’s a normal characteristic of the vehicle other 2023’s on the lot did the same thing. Complain and report it. I’ve disengaged SOS, Wi-Fi and pulled the head unit to inspect no fix. Keep us posted if you figure out anything.
  9. May 3, 2023 at 7:56 PM
    #69
    Hilux1
    Hilux1 Well-Known Member
    Jon
    Colorado
    2022 Tacoma SR5 Double Cab, 4x4 V6, AT
    Wanted to add my name to this list. I’ve had it since I bought mine new back in Aug 2022. Wife has a hard time hearing me with the buzzing noise.
  10. May 3, 2023 at 8:11 PM
    #70
    CriusTitan
    what’s your details, trim level and build location?
  11. May 3, 2023 at 9:21 PM
    #71
    Hilux1
    Jon
    Colorado
    It’s a 2022 SR5 with the tech package and I believe was built in Mexico. My phone I’m using is an iPhone12 and I mainly use it plugged in with CarPlay.
  12. May 5, 2023 at 6:02 AM
    #72
    Hilux1
    Jon
    Colorado
    I did the transmit volume while using Bluetooth and that fixed the noise. I still have it while using CarPlay though, but only when the truck is running. It wasn’t there when I was using it parked and just using the accessory mode.
    My guess is it’s something inside the engine bay that’s interfering.
  13. May 31, 2023 at 5:25 PM
    #73
    CriusTitan
    Post in thread 'Apple CarPlay/Bluetooth Issue???' This fixed the problem for me
  14. May 31, 2023 at 6:16 PM
    #74
    Hilux1
    Jon
    Colorado
    Does this work using CarPlay? I was able to fix mine with the Bluetooth using the methods posted above but there wasn’t a way to do it while on a call using CarPlay.
  15. May 31, 2023 at 6:26 PM
    #75
    CriusTitan
    Yes this is for CarPlay not sure if it works for bluetooth I don’t use that but I’m sure it does, the transmit volume hack didn’t work for me.
  16. May 31, 2023 at 6:39 PM
    #76
    Tallnslim
    Tallnslim Member
    2023 white tacoma SR 4x4 3.5L Access cab
    Guys guys guys I have the fix for this.
    YOOO All. I have the fix for this. I have a 2023 sr that I did it on and it worked like a charm. The feedback issue is a software settings issue and not a hardware issue.
    1. Turn off your truck.
    2. Turn key to on, but do not actually start the truck. Press down and hold the audio button by the screen and turn the lights on and off 3 times. Now release the audio button and you will be in diagnostic mode.
    3. Select "function check/setting" from the service menu screen.
    4. Select "HF Voice Quality Setting" from the "Function Check/Setting I" screen.
    5. Use the number pad on the screen to type in 2000.
    Press the save (I think it said save at the bottom, but do not recall clearly).
    Turn off and turn the vehicle on. If you did as noted above there will be a significant improvement of audio quality to the people on the other side of your phone calls.
    Best~
  17. May 31, 2023 at 6:44 PM
    #77
    DBTrail22
    DBTrail22 Member
    Okay not sure if I believe the above reply since I can’t imagine turning on and off the lights 3 times would do anything but I’ll try.
    I have the same issue since I bought the truck. Mine is a 22’ Trail Edition and the callers on the other end say that my voice fades in and out and seems distant at times along with the notorious buzzing sound. I just put in an AirPod every time someone calls which is RIDICULOUS since it should work correctly!
  18. May 31, 2023 at 6:54 PM
    #78
    Tallnslim
    Tallnslim Member
    The keys thing is to open the diagnostics mode. You can try to do the other steps without that, but i dont know how you're going to get to that menu.
    I had a lotta feeback and my freind would bitch a lot about it, but now only occasionally it has some slight feedback/buzzing. I did it today and i didnt think it would work but it did. Please lmk when it works successfully!! ^^
  19. May 31, 2023 at 7:02 PM
    #79
    CriusTitan
    It really does pull up the menu. Interesting find. But what is the default value it is at. I don’t want to just randomly change it without knowing
  20. May 31, 2023 at 7:08 PM
    #80
    CriusTitan
    Okay default is just the 0000 after googling
    here’s a write up
    https://static.nhtsa.gov/odi/tsbs/2015/MC-10152266-9999.pdf
