Radio/Head Unit won't turn off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dmreed, Feb 20, 2021.
  1. Feb 20, 2021 at 8:45 PM
    Dmreed
    Dmreed [OP] Member
    Devin
    2017 Metallic Grey Tacoma TRD Sport
    I've got an issue that started today (02/20/2021) or possibly last night (02/19/2021) where on my 2017 Toyota Tacoma won't fully power off. Upon turning the truck off and getting out of the vehicle. The truck starts to beep saying "Key Fob Not Detected" even though I'm not in the truck at all. After about 10 seconds, the radio/clock/head unit all turn back on and won't turn off. The key fob will no longer lock or unlock the doors either. I just had my batteries replaced in my key fob as well as my battery checked at autozone. If anyone has ANY suggestions please let me know.
  2. Feb 20, 2021 at 8:48 PM
    Bishop84
    Bishop84 Well-Known Member
    What happens if you hold the power switch?
  3. Feb 20, 2021 at 8:49 PM
    Dmreed
    Dmreed [OP] Member
    Devin
    while pressing the brake or no?
  4. Feb 20, 2021 at 8:50 PM
    Bishop84
    Doesnt matter, its the panic turn off function.
  5. Feb 20, 2021 at 8:54 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    What’s happening is your truck is going back into accessory mode once you turn it off.
    Do you have any aftermarket accessories on the vehicle that can cause this?
  6. Feb 20, 2021 at 8:56 PM
    Dmreed
    Dmreed [OP] Member
    Devin
    as far as i know the vehicle is completely stock upon me purchasing it
  7. Feb 20, 2021 at 9:01 PM
    Dmreed
    Dmreed [OP] Member
    Devin
    just tried this, nothing happened at all. radio and head unit stay on as well as the P next to the shifter
  8. Feb 20, 2021 at 9:02 PM
    brandon78lusch
    Brandon
    this happened to a few other people and each one was caused by different things. It could be the transmission, push button, battery, key fob, etc.
    take it into the dealership
    its probably an issue with the push button start
    MaverickT883 likes this.
  9. Feb 20, 2021 at 9:12 PM
    Dmreed
    Dmreed [OP] Member
    Devin
    thanks for the info, hopefully they can get it checked out.
    i just tried to lock the door by "squeezing" the ridges on the drive side door handle and it said on the dash "turn power off" so there is no telling what it could be lol
  10. Feb 20, 2021 at 9:14 PM
    Dmreed
    Dmreed [OP] Member
    Devin
    someone just mentioned on my facebook group that it could be an issue with the wires either shorting or not being grounded properly...
  11. Feb 20, 2021 at 9:16 PM
    Bishop84
    Definitely sounds like a start button issue. I'd disconnect the battery over night and reconnect in the morning. Otherwise it needs to be diagnosed properly.
  12. Feb 21, 2021 at 5:12 AM
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    This happened to me after I got my windows tinted. There’s a master power switch in the driver side door to detect the smart key. It likely got wet during the tint causing it to act up. I disconnected the battery and threw a dehumidifier into the truck over night, and that took care of the problem.
    Edit: Another guy on here who said he had this problem said his was caused by too many fuse taps. If you search “Tacoma won’t turn off” and some similar searches, there are a couple of threads on here about this, but not a ton of answers.
  13. Jan 1, 2023 at 3:24 PM
    TacomaRemy
    TacomaRemy New Member
    Remy
    Portland
    2018 quicksand TRD off-road
    Mine ended up being the auto turn on switch on my amp. Had accidentally flipped it from 12v to DC and was causing the whole issue
  14. Feb 1, 2023 at 3:11 PM
    Frank_taco
    Frank_taco New Member
    Yes I do. I installed a sub in my truck. It just started this today.
  15. Feb 2, 2023 at 8:09 AM
    TacomaRemy
    Remy
    Portland
    Check that 12v to DC switch on amp. If switched to DC it will continue to draw power after you turn truck off leaving it in accessory mode. Switch back to 12v. This solved my problem
  16. Feb 2, 2023 at 8:30 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I had an issue like this once. I had my GoPro plugged in and charging via the cig lighter. For some reason, it was like back feeding and giving me those messages.
  17. Nov 2, 2023 at 3:33 AM
    Thehybrid
    Thehybrid Member
    Danny
    Rims,Lights
    Hi, did anyone managed to fix the issue my 2020 tacoma started doing this yesterday. Push the switch button to shut engine off, but the radio seems to be turning back on, and the keyfob does not lock or unlock doors, already swapped the key fob batteries but still the problem lingers.
    Anyhelp???
  18. Nov 26, 2023 at 3:26 AM
    Thehybrid
    Thehybrid Member
    Danny
    Rims,Lights
    Mine is doimg the exact same thing, did you managed to fix it?
  19. Dec 21, 2023 at 6:58 AM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    Having this exact issue right now. Completely stock truck. Anyone figure this out?
