radio on till you open door?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wbhvacer, May 8, 2009.
  1. May 8, 2009 at 8:27 PM
    wbhvacer
    wbhvacer [OP] Well-Known Member
    Cartersville Ga.
    Dodge Challenger Rt
    Does anyone know how to or where i can find out how to mod radio to satw on till you open the door?
  2. May 8, 2009 at 9:41 PM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    not sure but on mine, its the opposite. i got an alarm (clifford alarm) and if i have the key in the ignition and turn it to ACC or ON then take the key right out my radio will stay on till i shut the door.
  3. May 9, 2009 at 7:59 AM
    bigtex2884
    bigtex2884 Well-Known Member
    Austin, Texas
    08 prerunner
    Retro Projectors, tinted tails, nfab nerf bars, avhp4000dvd, kicker 700.5, 2 8" comps, full components front and back, scangague 2, HID Fogs, Muth Mirrors, 5100s front, 90000s rear. Maxtrac spindles, all pro expo pack, level 8 tracker 16" x 8 1/2
    what u want is something all the new gms do. I think it would be a bit more difficult than just "hooking up a wire". Actually the more i think about it you cant do it. On the gms its done all though a computerized system, it would be impossible to do it with just relays and diodes and such.
  4. May 9, 2009 at 8:05 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Fords do it, too. My parents have a base-model 2006 F250 that does that. Freaked me out a little the first time I took the key out and the radio wouldn't quit.
  5. May 9, 2009 at 8:14 AM
    AZFizik
    AZFizik Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    It would NOT be impossible to "just" do it through relays and stuff. If you're really that interested in having a radio on till door open, you're going to have to get creative.
    You'll need signal from the door pin, and probably IGN1 and +12v off the main harness. Then run something like a 5 wire cut to turn off the power circuit to the radio when the door is opened and the pin grounds out. Its complex, but by no means is it impossible.
    If anything I said in that paragraph confuses you, do not attempt it. I've been thinking about this same mod, but I've got 8 years of automotive electrical experience.... If/when I do this I'll make a nice write up
  6. May 9, 2009 at 8:25 AM
    bigtex2884
    Austin, Texas
    08 prerunner
    k found someone who did it
    http://www.fordf150.net/howto/radiorelay.php
    just look at the relay diagrams dont read his colors its for a f150
    TACOMA DOOR TRIGGERS:
    The Body ECU is attached to the back of the fuse box. It has a single 26 pin plug. The individual door trigger wires are at the fuse box. The LF door is green/yellow in an 18 pin plug, pin 7. The RF door is red/black in a 22 pin plug on the back, pin 8. The rear doors are pink/black in an 18 pin plug, pin 6
    OR
    Green/White In the Instrument cluster (Door Ajar Indicator)
  7. May 9, 2009 at 8:30 AM
    BioMed80
    BioMed80 Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
  8. May 9, 2009 at 5:39 PM
    wbhvacer
    Cartersville Ga.
    Dodge Challenger Rt
    As always people here are willing to help if they can.Thanks for all your help
  9. May 10, 2009 at 4:38 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    And if you have any trouble understanding or locating wires, PM me.
