Radio static when Fan is on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brow, Jun 21, 2018.
  1. Jun 21, 2018 at 11:07 AM
    brow
    brow [OP] Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    This one is new to me, and I have no idea where to start. Truck is still under warranty so I'll be taking it in but wanted to see if anyone else has this issue. 2017 DCLB SR5
    I'm getting a lot of static from the front passenger side speakers (it almost sounds like water rushing through my dashboard) whenever the fan is on in my truck. Oddly, and I can't make this crap up, it only happens when turning left. It has gotten progressively louder over the last week.
    Anyone have any guesses?
  2. Jun 21, 2018 at 3:10 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Speakers blowing you away huh.
    Thats the craziest thing I've heard.
    specter208 and Atl_taco_ like this.
  3. Jun 21, 2018 at 3:14 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Bad connection. Either speaker wire or fan. The try replacement is the fan. Or just drive around doing right turns.
    kgilly and Atl_taco_ like this.
  4. Jun 21, 2018 at 3:50 PM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Do you have HD reception for the stations you’re listening to?
    Are you charging your phone at the same time? If so with cable or QI?
    Is this music from the radio station or from your phone/app?
    Could be grounding issue/noise being introduced...are you using an AC inverter to charge anything like a laptop?
    cshrum likes this.
  5. Jun 22, 2018 at 5:13 AM
    brow
    Andy
    Minnesota
    2020 Dodge Ram 1500
    I do get HD signals on the radio. Nothing is being charged in the truck. It happens whether the radio is on or off, doesn't make a difference. The only common causes are left turns and the fan being on. Sounds like it might just be a random one off thing. We'll see what the dealer says
  6. Jun 22, 2018 at 7:40 AM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Maybe it IS water flowing through your dashboard! Plugged up AC drain. No way you could be hearing static through the speakers with the radio off!
  7. Jul 14, 2018 at 6:53 AM
    brow
    Andy
    Minnesota
    2020 Dodge Ram 1500
    to add another dimension to this, my passenger side carpet is soaked through, didnt notice it for who knows how long because of the weathertechs on top of it. There hasnt been any water on the floor mats themselves, which leads me to believe its coming from up near the firewall and soaking down through the carpet. It's been raining a ton here, so I dont know if there's a leak at the windshield or its related to the fan issue. Dealership appointment set up for monday morning now. ugh.
  8. Jul 14, 2018 at 7:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your AC drain line is clogged. The evap case is filled with water/condenstate. Enough that when turning left you slosh it and some hits the blower.
    Betting if you pull the AC filter it will be gunked up with leaves and debris too.
    The leak in the cab is where the drain line fits the evap case, and any external condensation the case may have from being cold.
    Highly doubtful it will be recognized as a warranty item, unless you just have a friendly dealer.
    You can use a shop vac and fit it to the AC drain line by the firewall, and see if you can break things free and drain the water.
    Get the mat out of the truck and let the drying procedure begin. Lifting the carpet at the edge by the door and placing a hair drier to blow under the carpet (no heat, air only) is a good start.
    Ok. I don't really 'know' all this, as I'm not there with your truck. However, it certainly has the symptoms of what I've seen before on vehicles with this problem. Across multiple marques and year models. And my initial remedy is free, non invasive, so worth a try.
    Cudgel likes this.
  9. Jul 16, 2018 at 9:25 AM
    brow
    Andy
    Minnesota
    2020 Dodge Ram 1500
    you were right on. AC drain line was clogged, and the sound was from water spilling out of the case whenever i turned. Sounds like they got it fixed and dried out and are covering it under warranty. New house we just moved in to actually has a garage to park in instead of under giant elms and cottonwoods like i used to, so hopefully this doesn't happen again.
    Clearwater Bill likes this.
  10. Jul 16, 2018 at 9:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Thank you for letting us know the results. Too many post problems, have suggestions of things to try, but never share the results.
    Since that was your issue, you might find the following thread of use. While the 'model' in this thread is a 2nd gen, I'm willing to bet tomorrow's lunch time Diet Coke that the 3rd gen is similar in design.
    https://www.tacomaworld.com/threads/rust-varmit-and-ac-clogging-prevention-project.557970/
    brow[QUOTED][OP] likes this.
  11. Jul 16, 2018 at 11:18 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Ask Matthew McConaughey for advice.
    In his commercial, the Lincoln does "alright, alright, alright..." only.
  12. Jul 16, 2018 at 11:29 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    don't think he said with the radio off? maybe something to do with them?
  13. Jul 16, 2018 at 11:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    See post 8 and 9.
    This one has a fork in it. :D
