Rajas con queso or chile slices with cheese
Discussion in 'Food Talk' started by 06tacomaprerunner, Oct 2, 2008.
  1. Oct 2, 2008 at 2:35 PM
    06tacomaprerunner
    06tacomaprerunner [OP] the foreigner
    B. C. Mex.
    06 PreRunner SR5 dbl cab shortbed, r
    BILSTEIN 5100, 1/4 inch wheel spacers,removed front mud flaps, 285/70/17 bfg mud terrain km2 and a lot of scratches in front and rear bumpers
    If you like tacos you have to try this recipe.
    Ingredients:
    • 4 chiles poblanos or ancho.
    • 1/2 onion
    • 250 gr of grain corn (granos de elote, sorry i don't know how to translate it)
    • 450 gr of monterrey jack
    • salt, black pepper and garlic to the taste (use almost nothing)
    • 4 spoon of butter or margarine.
    • 1 kg of corn tortillas
    Preparation:
    • Roast the Poblano chiles either in a cast-iron skillet over medium high heat, under the broiler, or over an open flame (such as your grill). Turn the chile frequently to prevent over cooking on any one side, and let the entire chile pepper become charred and blackened.
    • Remove from the heat and place in a slightly damp towel, allow to cool. Cooling the chile in a damp towel will help to loosen any skin that is still stuck on the chile pepper.
    • Once cool, carefully peel the skin from the chile pepper, remove the stem end, and slice open to remove the seeds. Once this is done, dice the chile in 1/2-inch by 1/2-inch pieces; set to the side until ready to use.
    • slice the onion, not chop.
    • now put the butter to melt on a frying pan at low heat
    • add the onion and the chile slices for 10 minutes
    • add the cheese slices and the corn and cover the pan
    • and when the cheese melt is ready to enjoy.
    I hope you enjoy.
    A few pics of the chiles
  2. Oct 2, 2008 at 2:38 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    Que interesante. este post esta muy bueno
  3. Oct 2, 2008 at 2:42 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I believe that granos de elote translates to corn kernels. Sounds yummy, I'll check it out sometime!
  4. Oct 2, 2008 at 2:44 PM
    06tacomaprerunner
    B. C. Mex.
    :laugh: thanks man!!
  5. Oct 2, 2008 at 3:02 PM
    Tman
    Tman Well-Known Member
    Woodstock, Georgia
    08 Silver TRD
    Stock (for now)
    Ahora tengo hambre !:D
  6. Oct 2, 2008 at 3:10 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    beastly, sabes hablar espanol???:confused:
    Pero si se oye muy buena esa receta....:cool:
    pero, como que falta un poco de carne... no?:D
