Rally armor flaps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DueToThe802, Jan 4, 2013.
  1. Jan 4, 2013 at 4:13 PM
    DueToThe802
    DueToThe802 [OP] Well-Known Member
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    dziner likes this.
  2. Jan 4, 2013 at 4:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Those are cheaper than buying a new set of OEM flaps
    Subbed for mounting ideas
    dziner likes this.
  3. Jan 4, 2013 at 4:23 PM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    I think I'd just use the normal mounting spots, can I buy the screws for OEM?
  4. Jan 4, 2013 at 4:52 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Looking at these or the Plasticolors. Interested in pics/info on install.
  5. Jan 4, 2013 at 4:53 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I looked into doing this a few weeks ago to have a higher clearance flap and came up with a general idea.
    One install would be to drill a hole pattern just like the OEM flap to match up with the clips and bolts. Of course the universal rally flap is flat so maybe longer bolts + spacers could be used for the bolt holes.
    Of course I have ZERO experience mounting flaps, and this was all thought up "in my head" thus if this would end up resulting in torn up flaps someone say so!
    On checking into those flaps though I realized they are the harder plastic kind which explained the pricing. And thus I realized I probably will end up with the 1st gen flaps some day, and mount them higher in the wheel well to be a higher clearance flap.
    EDIT: I did find a pic either on here or some other forum of a Tacoma (black reg. cab I believe) that had the rally flaps installed. I will see if I can find it. EDIT 3: HAHA found it! http://www.tacomaworld.com/forum/2nd-gen-tacomas/24985-rubber-plastic-mud-flaps-2.html
    EDIT 2: I realized you put up the 128 dollar flap, which is the softer plastic/rubber/whatever, lol those would probably be better than OEM. Rally has the $20 ish ones that are made of hard plastic. (this one was what I looked into possible buying: http://www.rallyarmor.com/store/universal-basic-plus-p-337.html
  6. Jan 4, 2013 at 5:05 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
  7. Jan 4, 2013 at 5:18 PM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    Well done, thanks for doing all that legwork. I think ill be getting something soon.
    dziner likes this.
