ramonortiz55 4runner build: La Venenosa - For Sale!
Discussion in '4Runner Builds' started by ramonortiz55, Apr 9, 2015.
  1. Jan 13, 2016 at 2:32 PM
    #341
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I had my TWSS give me a Uniden PRO 520XL cb radio for my 4runner build.
    Thanks bud @adanfon
    The thing with these cb radios is that they fit PERFECTLY in the ashtray location on the 3rd gen 4runners.
    Give you a clean, stockish look:
    To be able to achieve this, I remove the radio/ac bezel on the 4runner:
    I pulled the ashtray out and remove these two screws:
    Test fitting the CB radio:
    Trimmed the end brackets off with a dremmel tool and test fitted again:
    Used two strips of velcro between the plastic prongs and the top of the radio.
    This holds the CB radio in place:
    Connected my PL59 connector:
    Dont forget to order pizza. If you dont, this MOD will NOT WORK:
    Looks like Arizona is winning:
    So now I proceed to run the coaxial wiring for the cb radio. I purchased this mount from a member on T4R.org. The mount installs in the back hatch:
    Picked up the firering coaxial cable, the 18 feet version:
    I ran the coaxial cable from the front of the 4runner towards the back:
    Under the carpet on the driver's side:
    Under the door floor plastic panel front and rear:
    I then removed the plastic paneling in the rear driver's side area by the seat:
    Removed the driver's side back cargo paneling:
    Ran it thru this yellow vent thing:
    Here it is!
    I then hid it from view by running it behind the bumper:
    Made sure to install the cable like this:
    Acerwin, adanfon and BYJOSHCOOK like this.
  2. Jan 13, 2016 at 2:34 PM
    #342
    ramonortiz55
    Ramon
    Texas
    stock
  3. Jan 13, 2016 at 2:53 PM
    #343
    jkirkpatrick
    jkirkpatrick Well-Known Member
    Edmonton
    2018 4Runner TRD Offroad edition (2000 Tacoma sold in 2018)
    Lift, tires, wheels, bumper, winch, sliders, skids, regeared
    ramonortiz55[OP] likes this.
  4. Jan 13, 2016 at 5:35 PM
    #344
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'm gonna get the one that bends so I can put it under my RTT, not gonna help OP on the runner haha
  5. Jan 13, 2016 at 5:40 PM
    #345
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    @ramonortiz55 going to start on your switch sticker soon buddy
  6. Jan 13, 2016 at 5:43 PM
    #346
    ramonortiz55
    Ramon
    Texas
    stock
    out
    Acerwin likes this.
  7. Jan 13, 2016 at 5:43 PM
    #347
    ramonortiz55
    Ramon
    Texas
    stock
    thanks
    Acerwin[QUOTED] likes this.
  8. Jan 13, 2016 at 7:31 PM
    #348
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Fine! Unsubed
    :hattip::luvya:
  9. Jan 13, 2016 at 7:32 PM
    #349
    ramonortiz55
    Ramon
    Texas
    stock
    waiiiittt!!
  10. Jan 13, 2016 at 7:38 PM
    #350
    BYJOSHCOOK
    Josh
    Check Out My Builds
    :spy: :poking:
  11. Jan 13, 2016 at 8:44 PM
    #351
    RedRunner87
    RedRunner87 Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
    255/80 Falken Wildpeak AT3W
    Thank you sir. I am going to run it in reverse order since it maybe a bit till I get my CB in. Gives me a project for when I get back from Vegas. Question did you have to loosen the bumper at all, or did it fit between the gaps? Trying to remember if I have enough gap to fit it through.
  12. Jan 18, 2016 at 4:32 PM
    #352
    ramonortiz55
    Ramon
    Texas
    stock
    I went ahead and finally did the wiring for the winch this weekend.
    Well most of it.
    The reason it took me forever to get the wiring done was because I couldnt find a good spot to install my winch solenoid box.
    I wanted the controls to be accessible and I also wanted the box in a good spot where it wouldnt take too much space or require me relocating stuffss..
    I give credit to @BigFishAllDay build thread on T4R.org for this idea.
    Changed a few things, but the concept is all the same.
    So here is this big clunky thing:
    If I open it, I get a smaller clunky thing:
    The idea is to take the solenoid out of the box and mount it directly without a box.
    I studied the wiring, made sure I knew where everything was going and what every wire was.
    I decided to mount the controller jack inside the 4runner. These wires for the controller jack will be cut and extended with the connection inside the cab:
    before I cut the wires, I went ahead and removed the main lead wires and wrapped the solenoid in thick electrical tape to make it "waterproof"
    I cut off the winch controller jack and crimped on connectors at the solenoid and controller jack:
    Not only did i crimp them, but i also soldered the wiring on there for a dependable connection:
    Then I picked up some color matching wire and made the harness to extend the controller jack into the cabin of the 4runner:
    Once all this was complete, I looked for a suitable location for the taped solenoid.
    I saw a nice spot next to the battery:
    Its a little dark, but you get the idea. I Like the fact I can use the factory hole to run wires thru.
    Installed solenoid:
    Obviously the wiring that the winch came was not long enough for this location. I had to make my own wiring:
    I ran the wiring from the solenoid thru the hole in the inner fender and towards the winch:
    I then ran my controller jack wiring towards the 4runner cabin:
    Made all the connections for the controller jack wiring, taped them up nice and well to prevent any moisture from reaching the connections.
    I decided to get rid of these dummy switches and buy a tan switch blank to install my jack here:
    after installing winch jack:
    PcBuilder14 likes this.
  13. Jan 18, 2016 at 8:12 PM
    #353
    ramonortiz55
    Ramon
    Texas
    stock
    @BigFishAllDay did you ever have any long term problems with this mod?
  14. Jan 18, 2016 at 9:15 PM
    #354
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Have you decided where are you going to put the controller plug in the cab? Here is where I put mine.
  15. Jan 19, 2016 at 4:35 AM
    #355
    ramonortiz55
    Ramon
    Texas
    stock
    once i get a new switch blank ill place it here
  16. Jan 19, 2016 at 4:35 AM
    #356
    ramonortiz55
    Ramon
    Texas
    stock
    @Digiratus did you take your solonoid out of the box also?
  17. Jan 19, 2016 at 7:49 AM
    #357
    Digiratus
    Roaming the PNW
    The RedHead
    I did not. It is still in that outer plastic box. I thought that box would offer a bit more resistance to the elements that way. I did seal it up a bit better tho with a little strategically placed silicon.
    I haven't experienced it myself, but I've read that the contractor, that piece that handles all of the winch power, is or has been vulnerable to corrosion. So I didn't want to expose it further.
    My controller box is tucked into my bumper, in the passenger side wing next to the winch. Since I have a plate bumper it is hidden from sight.
  18. Jan 19, 2016 at 7:59 AM
    #358
    ramonortiz55
    Ramon
    Texas
    stock
    I am going to see if i can retro fit a smaller box to cover up my taped up solenoid.
  19. Jan 19, 2016 at 8:00 AM
    #359
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    Nice job getting everything wired up! Do you have a kill switch for the winch?
    This happened to some guys in CO. Just an fyi
  20. Jan 19, 2016 at 8:02 AM
    #360
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hence its called Shittybuilt
    Glad everybody was ok
