ramonortiz55's scandalous build - if it doesn't feel right, you're doing it right
Discussion in '2nd Gen. Builds (2005-2015)' started by ramonortiz55, Aug 19, 2015.
  1. Jan 1, 2016 at 6:23 PM
    #101
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    @HBGIBBY did that camera work for you?
  2. Jan 1, 2016 at 7:48 PM
    #102
    HBGIBBY
    HBGIBBY Well-Known Member
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    I didn't get it, I know....I know...., but my dad wouldn't fund it!!!!!
  3. Jan 2, 2016 at 3:27 AM
    #103
    ramonortiz55
    Ramon
    Texas
    stock
    huh?
  4. Jan 2, 2016 at 3:27 AM
    #104
    ramonortiz55
    Ramon
    Texas
    stock
    ohhhh haha okay. so someone else beat you to it :(
  5. Jan 6, 2016 at 12:01 PM
    #105
    ramonortiz55
    Ramon
    Texas
    stock
  6. Jan 6, 2016 at 12:08 PM
    #106
    HBGIBBY
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    nobody cares
  7. Jan 6, 2016 at 12:15 PM
    #107
    ramonortiz55
    Ramon
    Texas
    stock
    you did :D
  8. Jan 6, 2016 at 12:15 PM
    #108
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    :burnrubber:
    :rofl:
  9. Jan 15, 2016 at 10:20 PM
    #109
    ramonortiz55
    Ramon
    Texas
    stock
    So I picked up a battery tray from @Iggy. a few weeks ago. @Iggy. and I are working on a battery tray for a dual battery setup. This is still preliminary, therefore any advice or ideas are greatly appreciated!
    Any ideas gathered from here could be incorporated in a final battery tray setup.
    Let's see where this goes, shall we?
    Finally going to get it setup.
    This is what I received in the mail:
    Battery tray along with a bracket to hold a busman fuse/relay box!
    So here goes the experimentation:
    The battery tray is designed to go over the fenderwell on the passenger side of the second gen taco.
    One problem. I have this pesky emissions pump.
    We must relocate this.
    So my initial intensions is to relocate the pump here in the area where the steering fluid reservoir sits at:
    Let's start by removing this sucker:
    If I relocate the pump, I will need to extend the hose and extend the wiring connections:
    Removing the pump is easy:
    Once it is out of the way, I place the battery tray in the same spot.
    This bracket is in the way. Looks like it hold a rubber clamp on these ac lines:
    I figured I could flip this clamp the other way to avoid it hitting the battery tray:
    removed clamp
    flipped it the other way:
    I also had to flip the bracket the other way.
    Fitting the tray in, it bolts down in three locations. Two of them are here:
    According to @Iggy. those screws popping thru must be cut off. I will leave them in for now.
    I had to remove the bolt holding that side of the air intake assembly and slide the tray under it.
    I noticed this to be too close to the tray, so I figured I could flip the clamp and flip the bracket to lower it down and away from the busman holder bracket.
    I removed the tape and removed the nuts on the bracket to flip it:
    Flipped:
    So I need to relocate this bracket. Probably mount it against the firewall away from the battery and battery tray:
    Mounted my @Yotamac bussman box:
    Looks clean huh?
    So far so good.
    So now that I removed the emissions pump and plan to place it in the area of the steering pump reservoir, I need to find a place to relocate the steering pump reservoir.
    Reservoir removed:
    Removed the reservoir from its bracket:
    If I place the emissions pump in the spot where the steering pump reservoir is at, where would we put the reservoir at?
    It is just a question of extending the hoses and coming up with a bracket to mount it on..maybe mock up this holder part and bolt it somewhere else?
    Could we incorporate the holder part of the reservoir stand to the emissions pump stand?
    ideas please..
    EDIT -
    final solution here and onwards:
    https://www.tacomaworld.com/threads...-experimentation-thread.410758/#post-11591402
  10. Sep 22, 2016 at 3:20 PM
    #110
    ramonortiz55
    Ramon
    Texas
    stock
    Quotes and links for future mods:
    L-Tracs and tie downs for the beds:
  11. Sep 22, 2016 at 3:25 PM
    #111
    T4RFTMFW
    T4RFTMFW Well-Known Member
  12. Sep 22, 2016 at 3:26 PM
    #112
    ramonortiz55
    Ramon
    Texas
    stock
    so scandalous
  13. Sep 22, 2016 at 3:26 PM
    #113
    T4RFTMFW
    If it feels like you shouldn't be doing it, then it's going to feel great.
  14. Jun 29, 2017 at 8:15 PM
    #114
    ramonortiz55
    Ramon
    Texas
    stock
    what is so confusing?
  15. Jun 29, 2017 at 8:15 PM
    #115
    ramonortiz55
    Ramon
    Texas
    stock
    @HBGIBBY !!!!!! where have you beeeeeeeeennn!?!?!?
    HBGIBBY likes this.
  16. Jun 29, 2017 at 8:19 PM
    #116
    ramonortiz55
    Ramon
    Texas
    stock
    i do..
  17. Jun 29, 2017 at 8:20 PM
    #117
    ramonortiz55
    Ramon
    Texas
    stock
  18. Jun 29, 2017 at 8:32 PM
    #118
    ramonortiz55
    Ramon
    Texas
    stock
    my signature always had the 4runner..
  19. Jun 29, 2017 at 8:32 PM
    #119
    ramonortiz55
    Ramon
    Texas
    stock
    yup
    Blackout14 likes this.
  20. Jun 29, 2017 at 8:43 PM
    #120
    ramonortiz55
    Ramon
    Texas
    stock
    shes young...and innocent
    ruffridha9 and Blackout14 like this.
