Random Front End Clunk
Discussion in '1st Gen. Tacomas (1995-2004)' started by FettsVette, Feb 3, 2011.
  1. Feb 3, 2011 at 11:09 AM
    FettsVette
    FettsVette [OP] Member
    Albany
    02 Tacoma SR5
    Just bought my first pickup/first toyota. 02 Tacoma SR5 V6 4x4 TRD 5-Speed Manual with 80,000 mi. Truck seems to run great except this random metal clunking or popping sound that seems to occur for no reason, not necessarily just after hitting a bump, dont think it's a ball joint issue. The noise is definately d/s front end. Also this is my first time driving a stick, but I dont think its anything I'm doing because it doesnt seem to be affected by low/high speed or shifting. It is totally random. Any ideas? Thanks.
  2. Feb 3, 2011 at 3:06 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Greese your drive shafts and check U-joints.
  3. Feb 3, 2011 at 6:56 PM
    alexlies
    alexlies Well-Known Member
    Alex
    Battleground
    2002 4 door 4x4
    is there a body lift?
  4. Feb 4, 2011 at 2:58 AM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Your sway bar might be a little loose? I put aftermarket coilovers on my truck, took a shot at removing the sway bar to do it, thought I didn't get anywhere with it, and sure enough after I put everything back together had this odd clunking noise.
    Just a thought. Easy to tighten up.
  5. Feb 4, 2011 at 5:15 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Yeah check the sway bar. My sway bar bolts just kept spinning and spinning so I'm gonna have to grind em off
  6. Feb 4, 2011 at 5:28 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    any mods? ..or is it stock?
  7. Feb 4, 2011 at 3:11 PM
    FettsVette
    Albany
    02 Tacoma SR5
    No mods on it, I will check the u-joints but I'm pretty confident that's not it. I'm def gonna check out that sway bar issue. Thanks for all the advice so far
  8. Feb 4, 2011 at 3:26 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    check your tie rods, i had the same clunking/popping except my truck only did it when i was taking off
