Random Misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andrew3, Oct 6, 2015.
  1. Nov 2, 2015 at 10:58 PM
    #41
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I'd go stock air box, oiled air filters on aftermarket fouls maf sensors and have been shown to have little to benefit performance wise.
    That popping sounds a lot like spider gears, or a broken tooth on the ring and pinion, best way to find out is drain the diff, gotta stay 4.10's if that's what's in the back.
  2. Nov 3, 2015 at 4:40 AM
    #42
    NF2001Yota
    NF2001Yota Well-Known Member
    2001 4 door 4x4 toyota tacoma
    Ten4
    Do you know how to determine if the Maf Sensor is bad?
    Thanks
  3. Nov 3, 2015 at 9:03 AM
    #43
    Laxtoy
    Maltby, WA
    should throw a code, they don't usually go bad unless they have been fouled by an oiled air filter.
  4. Nov 3, 2015 at 9:47 AM
    #44
    NF2001Yota
    That's what I thought.
    It looks good, I cleaned it last night again.
    I am having same issues again. they just started coming back.
    So I think I might just set the truck on fire. Lol
    I drove it 80 miles with no issues. drove it in the woods and then on the 80 mile stretch back it starts the same symptoms of missing.
    I am going to get another diagnostic on it.
    I am going to have them check the; Coils, Fuel pressure, O2 levels, all vacuum lines.
    Its throwing the same knock sensor codes.
    I believe it has to be a bad connection or a short of some sort. It does kind of shift like a bad coil now though.
    But Its throwing the knock sensor codes again. :(
    FML
  5. Nov 9, 2015 at 4:57 PM
    #45
    old grouch
    old grouch Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    That looks like something I would really like to have! Followed the links. The first is good but the second tells about the app but no info on how/where to get it. Do you have any more info? TIA
    #45
  6. Nov 9, 2015 at 5:22 PM
    #46
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    :oops: Never mind. I found it.
