Random Power Loss.. Redux
Discussion in '4 Cylinder' started by jeverich, May 24, 2013.
  1. May 24, 2013 at 10:52 PM
    jeverich
    jeverich [OP] Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Having the infamous 2TRFE "Random Power Loss".
    Used to have it very rarely, now it's happening 4 or more times throughout an hour drive. WTF.
    Noticed it's only happening around 2000 RPMs, only when climbing a grade, and only when accelerating. It's really starting to bother me; even more so if it's a looming issue in the throttle position sensor.. can't have a truck shit the bed when I'm 50 miles into a National Forest.
    Nothing that I can address for the immediate future, will deal with it/investigate some more when I'm back from the Bering Sea in July.
    Any suggestions? Doesn't seem as though there were any definitive causes/suggestions out of the 1,000 other threads.
    My thoughts are pointing to fuel filter/pump.
  2. May 24, 2013 at 11:01 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
  3. May 24, 2013 at 11:05 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    That's what I'm thinking.
    What's strange is that it happens at all levels of gas. Full - 1/2 full, etc.
    I'm thinking that hills are forcing the fuel pump to work harder; the clogged filter is causing a momentary lapse in fuel supply.
    Let's keep this going, appreciate the real advice.
  4. May 24, 2013 at 11:07 PM
    PLC721
    Patrick
    Chandler, Az
    I agree, mine always happens under load especially pulling hills, 3/4 or half tank doesnt matter, i think your right about fuel pressure not keeping up and the engine leans out.
  5. May 24, 2013 at 11:07 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Wish I knew. My 4.0L six speed was doing that occasionally. It would feel like it had a carburetor with jets 3 sizes too small for a few seconds and return to normal again. I was suspecting intermittent fuel pump issues too, although far less often that yours - maybe once every couple months. Still, it was a factor in my decision to get rid of it.
  6. May 24, 2013 at 11:11 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Right on! Wow, was not expecting this amount of hits so soon...
    iroh - Yup, that's EXACTLY what it feels like. I know my FJ60 with a Weber Carb would have the identical feeling sometimes. Used to only take a second to clear itself, today it happened 4 times in a row.
    Really like the usability/serviceability of that URD kit. I know, not a great analogy - but we've got 3 sets of filters and a centrifuge just to clean diesel on the boat that I work on..
  7. May 24, 2013 at 11:13 PM
    PLC721
    Patrick
    Chandler, Az
    Urd fuel pump kit is next on my mod list
  8. May 24, 2013 at 11:27 PM
    2TRunner
    2TRunner Don't give up here just yet
    Around To Many People
    1, 2, 3, 4, 5 Lugs
    Brute Force Bumpers: rear & custom front tube, Saw-A-Way Racerunner 2.5 Coilovers with Total Chaos UCAs. Icon AAL.
    I have never experienced, or heard of anything like this and I drive the piss outta my truck...are you guys manual trannys?
    Try unplugging the MAF when this stuff starts happening and running/driving the truck. The truck should run with the MAF unplugged in limp mode, I know Blazers will. Probably set a light, but it's very easy to tell if the truck runs better or not.
  9. May 25, 2013 at 1:58 AM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Up until now it's just been a kind of, "Wow, that's annoying".
    Last few days it's turned into, "This sucks, can't merge onto the highway, hope the truck doesn't die going up this mountain pass in the middle of a national forest...".
    Still thinking fuel, mainly because of the only on an incline factor.
    Definitely don't think it's a "mis-adjusted brake switch".
  10. May 25, 2013 at 4:03 AM
    2TRunner
    1, 2, 3, 4, 5 Lugs
    Give what I posted above a shot. Try unplugging the MAF when it starts happening, drive, see if the truck runs better. Won't hurt anything other than popping the CEL.
    Definetly interested in helping figure this one out. My shop is the shop where other shops send their cars cause they can't figure out the problems.
  11. May 26, 2013 at 9:55 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Pretty sure it's the brake pedal position sensor...
    I say this because while heading to the trailhead this morning, the truck behind me was watching my break lights come on exactly when the deceleration would start. Odd, because when I press on the brakes and gas at the same time, there is no speed change.
    Hoping it's that much of an easy fix.
    Will keep everyone in the loop; not going to mess with this one until I'm home again in a month or so.
  12. May 26, 2013 at 9:56 PM
    PLC721
    Patrick
    Chandler, Az
    Keep me posted!
  13. Jul 2, 2013 at 3:31 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Brake pedal position switch...! I'll elaborate later.
