Raptor liner for chrome bumper or powder coat?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tango down, Mar 2, 2012.
  1. Mar 2, 2012 at 6:08 PM
    tango down
    tango down [OP] Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    I did a search but found little about Raptor Liner Kit on this site. There was a nice write up on some dodge truck in the bed. It looked good and seems easy enough to spray.
    Has any here used it and have experience with it over one year? How has it held up? Better than a rattle can rustoleum bed liner? I am sure it is not as great as Line-x.
    I am brain-storming the idea of Raptor-lining my chrome rear bumper. Would that work well if I roughed up the surface with sandpaper? I'll probably also do some nerf bars.
    Another question....there is a great place here locally that does nice powder coating. Could the rear bumper be done? I only ask as its chrome and I figure he'd have to blast it a little first, then PC it.
    ANyway, thanks TW gurus
  2. Mar 2, 2012 at 6:38 PM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2016 MGM TRD OR 4X4 DCSB
    Tint
    I sanded mine, primered and black rattle canned it.
  3. Mar 2, 2012 at 6:45 PM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 Mini Tank
    Rock Crawler
    Rutoelium'd most a lot of my truck and couldn't be happier for the investment spent
  4. Mar 2, 2012 at 8:35 PM
    badger
    badger Well-Known Member
    07 SR5
    Raptor is what I plan to use for several things. I have researched on other sites and it seems to be a very high quality product. I prefer these finishes to powdercoat on bumpers. Either way, you should probably sand blast it. Sanding chrome does not work. It's too hard.
    You can buy the Raptor in a kit that comes with a special gun. You can control the roughness of the surface with the air pressure. It's best to put down a couple coats at higher pressure, then lower the pressure for the last coat to create the texture you want.
  5. Mar 2, 2012 at 8:49 PM
    tango down
    jeff
    Thanks badger, good pointer on the texture. I also didn't know Chrome was harder, I am learning a bunch. Thanks gang
