RatioTek transmission upgrade how to
Discussion in 'Performance and Tuning' started by mightytacoman, Jan 12, 2018.
  1. Jun 2, 2018 at 10:17 AM
    #61
    EL BOOGIE
    EL BOOGIE Well-Known Member
    Robin
    Sacramento
    2012 TRD Offroad
    my right foot
    If I am understanding correctly the internals of different year valve bodies might be different? My truck is a 12 I have a spare 07 transmission. If I do the mod on the 07 VB and just replace the 12 will it work even if the internals might be different?
  2. Jun 4, 2018 at 1:31 AM
    #62
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    It should work. When you swap them, check to see if the valve bodies match in terms of shape and check ball locations. I believe they will.
    EL BOOGIE[QUOTED] likes this.
  3. Jun 29, 2018 at 8:39 PM
    #63
    bendilzerian
    bendilzerian Well-Known Member
    Houston
    2015 DCSB White TRD Sport PreXrunner
    I'm really interested in doing this...but wouldn't attempt it on my own.
    @mightytacoman you did the RatioTek kit? Does anybody know if the IPT kit is the same thing?
    I'd be interested in finding a low mileage trans and sending it off to them to be built, then swapping that in myself. Keep my low mileage '15 as a backup.
    This trans shifts extremely slow. I've experienced some hang before going into 5th as others have as well.
  4. Jun 29, 2018 at 8:45 PM
    #64
    ThomasMore66
    Dallas/Fort Worth & Durango
    #64
    jojotoo likes this.
  5. Jun 29, 2018 at 10:06 PM
    #65
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    So you haven’t installed the ratiotek? Or you have and don’t like it?
    #65
  6. Jun 30, 2018 at 12:14 PM
    #66
    ThomasMore66
    Sitting in the box in my garage. It’s not happening. Going with the Australian valve body referenced before. Much more money, but I think you get what you pay for. Talked to the distributor and got info on what they do to the valve body. I was sold.
    07 sport 4x4[QUOTED] likes this.
  7. Jun 30, 2018 at 12:29 PM
    #67
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Did you get the HD ratiotek kit? What all do they do to the nomad valve body? My transmission has gotten where it’s not shifting as fast or firm anymore, thinking the ratiotek would be fine for my bone stock tacoma.
  8. Jun 30, 2018 at 1:06 PM
    #68
    ThomasMore66
    Regular Ratiotek.
    Wholesale Automatics started out as a general-purpose transmission shop and went into the manufacturing business because they wanted better results at a price point than could be had by simply installing some springs and whatnot. Development of the Nomad line of HD valve bodies over the last 25 years was the result of that need. The WAT product is redesigned and re-engineered so when it is manufactured in the WAT valve body shop, they use a mix of remanufactured OEM housing, together with in-house manufactured plates, springs, solenoids, etc. When it is complete the VB is then dyno tested to ensure function as designed, with pressure readings under various conditions - gears and torque converter pressures. I figure it will go well with my supercharged setup since I’m about to drop a couple more pulley sizes, add headers and hi-flow cats.
    5thGearPinned likes this.
  9. Jun 30, 2018 at 1:23 PM
    #69
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    So how much are we talking for the nomad?
  10. Jun 30, 2018 at 1:25 PM
    #70
    ThomasMore66
    $1295. Not at all cheap. IPT trans is more.
  11. Jun 30, 2018 at 1:28 PM
    #71
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    From what I've read, the ratiotek kit is just a shift kit that will only improve shifting and addresses nothing else. The IPT VB job replaces some of the aluminum sleeves that are prone to premature wear and it includes the shift kit. $30 for a shift kit from ratiotek is a heck of a deal to improve shifting but it won't improve longevity like IPT or some of the other options.
  12. Jun 30, 2018 at 1:33 PM
    #72
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Y'all know that the 4.7L V8 (Toyota 2Uz-FE from Tundra, Sequoia & 4Runner) uses the same automatic transmission that's in our Tacos?
    If the trans can handle the much higher torque from the V8 then why are y'all worried about it just behind the V6?
  13. Jun 30, 2018 at 1:35 PM
    #73
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    We putting down higher numbers brah
    ThomasMore66 likes this.
  14. Jun 30, 2018 at 1:38 PM
    #74
    TireFire
    Olympic Peninsula
    Maybe some of you but even the supercharged V6 doesn't get the V8 torque values unless it's seen some serious tuning...
    And the V8 also used to have an optional TRD supercharger or you can get the URD belt turbo kit and really blow the doors off any V6
  15. Jun 30, 2018 at 1:43 PM
    #75
    yota243
    E.J.
    north Alabama
    Dunno for sure, but I bet there were tranny upgrades needed for a sc 4.7. My turbo at 4 psi is enough to upset my tranny 7.5 psi is gonna really piss it off
  16. Jun 30, 2018 at 1:47 PM
    #76
    TireFire
    Olympic Peninsula
    Wonder if the V8 trans uses a different valve body then, the bell housing and TC arefor sure different too
    yota243 likes this.
  17. Jun 30, 2018 at 3:01 PM
    #77
    ThomasMore66
    I’ll run your Tundy...
    Pcyc likes this.
  18. Jul 3, 2018 at 5:36 AM
    #78
    mightytacoman
    Kel
    4.5L 1grfe
    @12TRDTacoma has been running the ratiotek without issue for what 40K in miles so far? I'm at about 12k on my setup with it. It does address wear issues by limiting slip. It does not address internal wear inside the valve body. Any of the wear parts can be replaced with transgo parts. Still cheaper than IPT.
    12TRDTacoma likes this.
  19. Jul 3, 2018 at 5:47 AM
    #79
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    How serious is the internal wear on the vb? After how many miles does it become a problem? I know we are boosted so it’s under my stressed but my work truck has the same trans/4.0 and it’s close to 353k and still shifting good *knocks on wood*
  20. Jul 3, 2018 at 5:57 AM
    #80
    mightytacoman
    Kel
    4.5L 1grfe
    I can't give you a mile number where they might go bad. Too many Variables. My truck has 170k+ no issues after the Ratiotek install. Supercharger installed around 130k with the 2.825 pulley installed at the same time.
