Rattle under glove box
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lpr5006, Jun 11, 2010.
  1. Jun 11, 2010 at 9:00 AM
    lpr5006
    lpr5006 [OP] Member
    Luke
    PA
    Super White TRD
    Does anyone else have an extremely annoying rattle in the glove box area of their 2nd gen tacoma? I have been trying to find it for some time now with no success. Only does it for low rpms.
  2. Jun 11, 2010 at 9:01 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    It's most likely just a loose bolt. Open it up and take the glove box out and tighten it up.
  3. Jun 11, 2010 at 9:05 AM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    do a search for this...many fixes
  4. Jun 11, 2010 at 9:05 AM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Yup i did have it. I searched around here for a while and a lot of people said it was some wires behind the glovebox. So I took it into the dealer and told them about the rattle and they fixed it. They also said it was some wires behind the glovebox and they just taped them up
  5. Jun 11, 2010 at 8:16 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Depends on the rattle. Mine was at extremely low RPMs where the engine was bogging just a little (like before downshifting on an uphill). It was the nut on the passenger airbag module...a common problem on the double cabs.
    The other common problem is the bundle of wires down there vibrating (I haven't had this problem).
  6. Jun 11, 2010 at 8:19 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    I had the bundle of wires buzzing. I taped them up and it went away for about a year, now they only buzz when it is really cold out. I just deal with it now. Next time I change the cabin air filter I will add a bit more tape.
  7. Jun 11, 2010 at 8:22 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
  8. Jun 11, 2010 at 8:23 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I had a loose nut behind the glove box that would rattle ever time I hit a bump , dealer fixxy for me .
  9. Jun 14, 2010 at 1:07 PM
    lpr5006
    lpr5006 [OP] Member
    Luke
    PA
    Super White TRD
    Thanks, I really like your wheels btw (Dark Taco). I have been trying to find some but with no luck. Anny suggestions?
  10. Jun 14, 2010 at 1:16 PM
    llcreel46
    llcreel46 Member
    Cedar Park, Tx
    09 PreRunner
    Air bag clips were missing and dealer reintalled.
  11. Jun 14, 2010 at 1:39 PM
    Dark_Taco
    2023 TRD Pro
    Stock
    My local dealer ordered them for me. $135 a wheel
  12. Jun 14, 2010 at 4:14 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    I fought this problem and zip tied and taped the piss out of everything I could and no better. I happened to hear afaint version when running while checking under hood and could cancel it while pressing down on the plastic shroud over the engine that contains air filter. My sound was caused by this vibrating and rattling against the valve cover. I used a bungi around the air intake flexible-hose/plenum and strapped it over to passenger inner fender and viola, fixed. As a more permanent fix I cut a 3/8" long piece of rubber fuel line and inserted it as a spacer to run the front/passenger shroud hold-down bolt through. The bolt was long enough and been solid now for several months. This was on v6.
  13. Jun 14, 2010 at 7:43 PM
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    My rattle was from the actual gray piece that the glove box sits on. You can take the glove box out and bang gently around the area where it sits on and you can hear the rattle. Put pressure in that thin piece and then bang and you hear nothing.
    My buddy at Toyota actually got a piece of wire and wrapped it around that piece and a metal piece and tightened it down. It hasn't rattled in two years and you would never know it is there and you can't see it.
    But man did it drive me crazy before it was fixed!
  14. Jun 14, 2010 at 7:46 PM
    jandrews
    '09 FourDubDee TRD OR
    Mine is still driving me insane.
    Have tried many solutions, no luck yet. Happens around 1400-1700 RPM.
  15. Jun 14, 2010 at 8:27 PM
    Airun
    Aaron
    Show Me State
    Try bungee cording the air plenum to engine compartment wall to see if goes away. It's absurd the number of different sources of the seemingly same sound that you'll read about atTW.
  16. Jun 14, 2010 at 8:39 PM
    airsoft_warrior
    airsoft_warrior Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    dealer replaced my blower motor under warranty.
