Rattle/vibration noise from under hood.
Discussion in 'Technical Chat' started by jrg66, Sep 3, 2008.
  1. Sep 3, 2008 at 8:13 PM
    jrg66
    jrg66 [OP] New Member
    bc-canada
    tacoma trd 4x4
    I recently checked my air filter to see if was dirty. I unclipped the two clips, pulled it apart, checked the air filter, then put everything together. Now when I start and back out my garage it makes a loud vibration/rattle sound. I doublechecked the clips and everything seems fine. the sound even vibrates even at around 1500 rpm going up slight hills and when I step on the gas.
    wondering if anyone has had this problem or any solution before I go crazy
    any advice would be helpful.
  2. Sep 3, 2008 at 8:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check the air hose where it goes into the fender.......that part may be loose
  3. Sep 3, 2008 at 8:18 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    make sure that the back 2 pegs are in their slots. u can still clip the front, but not have the pegs in and it'll prolly vibrate.
