rattling noise when cold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by redrx8, Oct 25, 2009.
  1. Oct 25, 2009 at 5:36 AM
    redrx8
    redrx8 [OP] Well-Known Member
    Hi, I just bought an 05 tacoma, I had a 93 previously. Now that the weather is getting cold, there is a rattling noise coming from the engine compartment. When I press the gas, the noise intensify but goes away when the engine warms up. It's not a valve noise but i can't seem to find anything loose, did it happened to anyone else? And what could it be?
    Thanks
  2. Oct 25, 2009 at 6:14 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    My 2000 made a tapping or ticking noise when below 40f and it went away when warmed up. My 08 does the same. Most posts on TW seem to say it is piston slap. I put an oil pan heater on this summer to see it it makes a difference but it hasn't been really cold here yet. I'll see what happens but even if it doesn't stop the noise it should make the warm up quicker. Everyone on TW says it won't cause any harm. Assuming it's the same noise hope this helps. If it's not the same noise don't read this. :D
  3. Oct 25, 2009 at 6:39 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    Check where the cold air intake joins the right fender. This has some foam around it, but it rattled when cold on mine until I learned of the TSB. Simple fix it to stuff some added foam around the plastic/metal union. Problem solved. This MAY be your cold rattle.
  4. Oct 25, 2009 at 7:06 AM
    AK27
    AK27 Well-Known Member
    mine does this too!
    starts as a rattle at like 15 km/hr and at 30km/hr it sounds like a vibration. any speeds above that and it disappears. only does it first thing in the morning too on a cold day.
  5. Oct 25, 2009 at 7:35 AM
    Warren Thompson
    Warren
    Elko, Nevada
    I had the exact same sympoms. I read on TW there was a TSB on this. I just padded the CAI where it entered the right fender well and the rattle dissappeared!! Try it!!
  6. Oct 25, 2009 at 7:37 AM
    AK27
    i'm going to try that this morning! thanks for the tip :D
  7. Oct 25, 2009 at 7:47 AM
    Warren Thompson
    Warren
    Elko, Nevada
    Hope it works. That is what TW is all about. Spread the word, spread the tips (sounds like a BBQ:D).
  8. Oct 25, 2009 at 12:28 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
    I plan to do this fix soon. On my first start reversing out of my driveway I have the rattle.
  9. Oct 25, 2009 at 12:53 PM
    Warren Thompson
    Warren
    Elko, Nevada
    YUP!!! My biggest rattling was reversing out of the driveway in the morning. It did not happen much when it was warmer during the summer, but when it started to get cool in the mornings, I noticed the rattle.
    I am pretty sure your fix is in adding some foam padding to the CAI hole in the fender. Should take you about two minutes.
  10. Nov 13, 2009 at 2:08 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Cool. I've heard this on mine as well.
  11. Nov 29, 2009 at 7:28 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    how about when you turn off the truck and it makes the knocking for like a min,, is that good or bad? I put in octane 87. I usually use BP or Shell gas!! Also, last winter in the cold, the engine's pulley would make this weird noise but once it warms back up, the noise is gone! what do u guys think?
  12. Nov 29, 2009 at 8:14 AM
    Evil Monkey
    Robert
    Escondido, CA
    It's bad to let it go on. I would put up a seperate post about it so the engine tech types can help you diagnose it. I think the problem is called "Post-Ignition". I believe it's a timing issue. Title your post something like "Engine Problems: Post Ignition." You should get some knowledgeable replies.
  13. Nov 29, 2009 at 8:20 AM
    ridereno
    ridereno Well-Known Member
    Tom
    Reno, NV
    2017 Tacoma DCLB 4X4 TRD-Off Road
    I have a 2007 that did it since new. I took it in at 35,900 miles to get covered under warranty, and the service tech said it was the intake on the fender. He was surprised that mine wasn't fixed with the new part. They installed a whole new plastic intake on the fender and I haven't heard a noise since! :)
  14. Dec 8, 2009 at 8:01 PM
    Bing
    Bing New Member
    Clarence
    Stayton, Oregon
    07Tacoma
    Running Boards Box Cover
    Thank you all for the speedy response. I'll check out the air intake first thing in the morning. Bing
  15. Jan 28, 2010 at 6:41 AM
    gcwaterski
    gcwaterski Well-Known Member
    Old thread- but glad to see this thread. My truck did this for the first time this morning. It was frosty out- and when I started the truck it sounded like the valves tapping pretty loud. I was like WTF! I bought this thing new and it has never done this in 70,000 miles. It went away as soon as it warmed up- but did not sound good at all. Its got plenty of good oil in it. Advise?
  16. Mar 28, 2010 at 7:22 AM
    hheil001
    hheil001 Member
    hunter
    baton rouge LA
    08 prerunner sport
    spin tech exhaust, K and N cold air intake, painted emblems black
    my truck does the same thing its an 08 with 40k.... loud valve sounding noise im going to take it to the shop soon.... does anybody else have this problem?
  17. Mar 28, 2010 at 8:10 AM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    Your sound is normal if it sounds like valve ticking. The others above are referring to the plastic intake pipe that goes through the fender. There is a thread about that ticking somewhere but it's normal.
  18. Mar 28, 2010 at 10:00 AM
    george3
    New Jersey
    I have no experience with 4.0's. I have a 2.7. I did a oil pan heater that I used this winter under 32F. I just switched to syn. No more tick this winter on dino with the heater. No tick on syn w/o heater this spring so far. Wonder if I'll need the heater next winter with syn.[​IMG]
  19. Mar 28, 2010 at 2:15 PM
    High-Gear
    High-Gear Zombie Killer
    Newton, KS
    09 TRD Off Road
    TRD Supercharger, TRD Cat Back Exhaust, DR / Icon 2.5 Coilovers, Camburg UCA, TSB with AAL, Walker Evans 2.0 reservoir rear shocks, ARB Bull Bar, Smittybilt 10K Comp Winch, ARE Camper Shell, Con-Ferr Safari Rack, 4 KC Highlights on rack, 2 KC Rallye 800 on Bumper Armortech Off Road plate rear bumper. Firestone Airbags in rear, with Firestone compressor.
    When it is very cold, 25f and under, I get an intermittant whine from my power steering pump as it warms up. I know it is coming from this, as it will change in pitch if I turn the wheel. When it warms up it goes away. I first thought it was a bearing that shot craps, but after the temp came up above freezine (two day later) it stopped doing it. Now every time it is cold I can count on hearing it. I guess it is normal.
  20. Mar 28, 2010 at 3:46 PM
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    Could be a cracked heat shield as that would explain why the sound goes away when the cat. converter warms up.
