Rattling type noise (Diesel sound)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Terrier, Aug 21, 2009.
  1. Aug 29, 2009 at 3:05 PM
    #41
    Terrier
    Terrier [OP] Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    Will be looking forward to your updates ninja_taco. Did they give you any details as to what they had to do to fix "the bearings in the transmission"? Have you driven it with the A/C on for any significant distance to see if cured?
  2. Aug 29, 2009 at 3:15 PM
    #42
    ninja_taco
    ninja_taco Well-Known Member
    Nick
    Louisiana
    '10 Prerunner
    Vanillarama Pinetree Scent
    i drove it with the a/c home, about 30 miles,to work and back about 20... so not too significant of an amount, but all with the a/c on. and they didnt elaborate on specifics but i saw the price of $863 that made me glad i'm still under warranty
  3. Aug 30, 2009 at 11:38 AM
    #43
    Lifeoffroad03
    Lifeoffroad03 Well-Known Member
    ICON Coilovers
    This is the typical toyota tic. I have had 3 toyotas one with the 3.4 and 2 with the 4.0 and they all amde that sound. I've been told it is toyotas fuel injection.
  4. Aug 30, 2009 at 1:00 PM
    #44
    Terrier
    Idaho
    Lifeoffroad03, thanks for your response; however, I do not think it is the typical Toyota "tick". I wish it were. Mine is more of a gear like sound that appears to be coming from the bell housing/transmssion area and it comes and goes, depending on whether the clutch pedal is up or down.
    Does the "tick" you are talking about stop when you press down on the clutch pedal and then come back when you let it back out?
  5. Aug 30, 2009 at 4:00 PM
    #45
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    No... this is not the fuel injector tick - or the A/C compressor, or belts, etc. It's definitely something in the transmission - because it stops when you push the clutch in and comes back as soon as you let it out with the transmission out of gear. I don't think it's the throwout bearing, because that comes into play when you push the clutch IN - and it's not doing anything when the clutch is in. Bad input or output shaft bearings or some other bearing in the transmission makes sense to me.
    Mine makes this sound too ('09 2.7 5-speed - with about 5K miles now) and has ever since new. I've been holding off on posting in this thread because I don't know if mine only does it when the A/C is on or not. I keep forgetting to test it. I suspect it does it all the time, but is more noticeable when the A/C is on because it drags the engine speed down a bit. If you rev the engine a little when it's doing it, you don't notice it as much... and then when it slows back down, the rattle is more obvious. It's REALLY obvious when you're right next to a building with your window down - as when in a fast food drive-thru line. You can hear it very well then.
    I had assumed this was just the nature of the beast - but if it's really due to bad bearings in my transmission somewhere, then I want it fixed.
    I'll be very interested to hear what you guys find out.
  6. Aug 30, 2009 at 5:44 PM
    #46
    hans2
    hans2 Member
    Same issue here on an '09 2.7 as reported in other similar threads. Scott Clark Toyota came to a surprisingly quick conclusion that the throw-out bearing was at fault--after only 3,000 miles. They replaced the original with a supposedly improved part, p/n 31230-35071, no questions asked.
    A day later the rattle returns. Definitely trans because of the clutch toggle. It's not AC-related but manifests itself better when the AC changes the engine idle speed. Brought it back to dealer and they claimed they couldn't hear anything. The rattle definitely gets louder when the transmission (not necessarily the engine) is warmer.
    Now the rattle has advanced to where it's noticeable out of gear when coasting to a stop. Surely Toyota NA has a spare 2.7 lying around that will exhibit this condition.
  7. Aug 31, 2009 at 7:35 AM
    #47
    Terrier
    Idaho
    You would think that with so many making this noise Toyota would have figured it out by now that it is not a problem, or if it is a problem, then what the heck is the fix.
  8. Aug 31, 2009 at 11:51 AM
    #48
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    i was told that toyota had never heard of such a problem when i first brought it in, obviously someone lied
  9. Aug 31, 2009 at 12:07 PM
    #49
    Raven65
    Camden, SC
    It seems to be standard operation procedure at Toyota to ignore or deny ALL problems until they generate an overwhelming number of customer complaints. THEN they'll finally issue a TSB (and not publicize it at all). That way, they only have to foot the bill to fix those vehicles that come into dealership service departments with specific complaints - and even then only those vehicles that are still under warranty. Of course they'll be glad to fix your out-of-warranty vehicle too - as long as YOU pay for it. Kinda sleazy really. Only safety-related issues generate RECALLS - which ARE publicized and cover ALL vehicles regardless of warranty status. The moral of the story is if you have any issues with your vehicle, make sure you file a complaint about it before your warranty expires - so you'll be covered if they ever issue a TSB for it.
  10. Aug 31, 2009 at 12:17 PM
    #50
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    i've aleady been in contact with a factory rep about it due to the fact that the second time i took it to them, after the a/c compressory didnt change a damn thing, i was told that it was an inherent noise and "thats whats up with that"... so i contacted toyota factory rep. its really quite annoying to deal with people like that. luckily the dealership im dealing with now are 100% better and actually seem to know what they are doing
  11. Aug 31, 2009 at 2:39 PM
    #51
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    well when the "noise" is messed up bearings, "imo" it needs to be fixed, whether its a minivan or truck or tank. why buy a brand new vehicle and have a defect when everyone else that buys it doesnt have the defect?
  12. Aug 31, 2009 at 3:28 PM
    #52
    Raven65
    Camden, SC
    Exactly, ninja...
    If it's by design (or lack thereof), that's one thing. If it's BROKEN (or might possibly break sometime in the future... like after my warranty expires) then I want it fixed.
    I don't buy the whole "its a truck, and its supposed to make noise" thing. Trucks used to cost much less than typical cars because they were simple no-frills utility vehicles. That argument might have held water back then, but now they cost MORE than a typical car. They're equipped just as well or better and employ plenty of cutting-edge technology and top-drawer components. There's no excuse for using crude, unrefined, noisy components in them anymore.
    ...and I'm not saying our transmissions are crude and unrefined... just the opposite. Which is why I don't think this noise is normal.
  13. Aug 31, 2009 at 8:07 PM
    #53
    Terrier
    Idaho
    The noise doesn't bother me at all. What bothers me is that I do not know whether it is a problem because it comes and goes with the push and release of the clutch pedal.
    In other words, it can make that noise all it wants as long as it does not effect the longevity of any component.
  14. Sep 1, 2009 at 12:53 PM
    #54
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    get it checked out. if you are still under warranty, what can it hurt to let them look at it? they found a defect in the throw out bearing, so they claim, but that didnt fix it... but now that they swapped the bearings in the tranny it seems to have fixed it, i hope
  15. Sep 1, 2009 at 7:26 PM
    #55
    Terrier
    Idaho
    I am not quite ready to have it torn apart until Toyota has in fact determined it to be a problem as opposed to just a noise, and until Toyota has made the dealer aware of the repair procedure as opposed to undergoing an investigative procedure. ninja_taco, I wish you had more detailed infromation as to exactly what your dealer did to the bearings in the transmission, what bearings, etc. Is there any part number referenced? Also, if you don't mind e-mailing me the name of the dealer that did the repair concerning the "bearings in the transmission", it would be appreciated. Thanks.
    Also, I have been trying to compile some sort of mental list as to whether all of those that have posted on this thread stating that their trucks have the symptoms have 4wd. I see a few prerunners that don't state whether they are 4wd. Are all prerunners 4wd? Maybe someone else can chime in on this potential pattern.
    Also, it would be nice if those that do not have the symptom could post and say so. Again the main issue is the noise going away when the clutch pedal is depressed and coming back when let up. I will try and start a survey on this in the 4 cylinder forum.
    Thanks everyone.
  16. Sep 4, 2009 at 5:43 PM
    #56
    Terrier
    Idaho
    I found out that Prerunners are not 4wd, so I guess there is no apparent pattern.
  17. Sep 4, 2009 at 7:06 PM
    #57
    Raven65
    Camden, SC
    Mine is a base model - reg. cab 5-lug 4-banger - 5-speed manual - and it makes this noise. It's not just 4WD models.
  18. Sep 4, 2009 at 11:54 PM
    #58
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    its not really the noise but yeah the fact that something could be wrong that worries me as well
    and BTW the 2TR's are MUCH MUCH noisier than the 1GR...even without the rattle
    and yeah my trucks not a 6 lug either...so i think it applies to all of them with the 5 speed
  19. Sep 5, 2009 at 12:23 AM
    #59
    socaltrucker00
    socaltrucker00 Well-Known Member
    Luis
    South California
    00' stepside tacoma
    rims
    having the same problem.. mine also sounds like if a hose like air is coming out :( but its nothig
  20. Sep 5, 2009 at 6:03 AM
    #60
    mikey05
    mikey05 Member
    05 DC Shortbed
    Too many to list
    You can speculate all day long about the possibilities here. Could be this could be that but the issue will not be resolved. Why not just drop the truck off and let the techs do their investigation. As you all sit here and speculate the truck gets more miles and time under its belt. Eventually there comes a point when problems compound(if there is one to begin with). Why make a possible issue worse when you could just drop it off and have the techs deal with it. I am no fan of the dealer and I do all my own work as a result. Just my 2 cents but I think someone needs to drop a truck off.
