RCD 4.5" or Pro comp 6"(basic kit)
Discussion in 'Suspension' started by silvertaco82, Jan 4, 2010.
RCD or Pro Comp
  1. RCD 4.5"
    52.6%
  2. Pro Comp 6"
    40.5%
  3. other(please post)
    6.8%
  1. Jan 4, 2010 at 4:51 PM
    silvertaco82
    silvertaco82 [OP] No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    I am starting to save up for a new lift have like $1000 from christmas and working. I was wondering for those of you that have RCD or pro comp lift how you like it and to post pics. I know there is a thread for 6" lifted trucks but it'd be nice to have it all in this thread to compare. Thanks for the help!
    Can't alter poll but another option would be toytec ultimate kit, tell me what you think of just getting ultimate kit?
  2. Jan 4, 2010 at 5:02 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    The RCD is $2100, if you want to you can save up a couple hundred more and get the Pro comp stage 2, that would be what I would do. Either kit is good, but if you are debating the 2, you get 2" inches of lift for a couple hundred.
  3. Jan 4, 2010 at 5:04 PM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2016 Limited DCSB 4x4 Blazing Blue
    Why get the RCD 4.5" if it is a drop bracket kit anyway. It will still require you to cut the crossmember most likely. I say if your cutting anyway you may as well go 6".
    You can still get 4" of lift out of other kits without cutting anything. I have 4" out of my Camburgs without preloading the springs or hurting the CV angles.
  4. Jan 4, 2010 at 5:05 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    in theory you can get better ground clearance with the rcd lift and 6 inch coil-overs, but the less expensive option to get 6 inches of lift would be the pro-comp--thats how im going to go
  5. Jan 4, 2010 at 5:07 PM
    ktmrider
    Junk
    yea you do still have to cut the crossmember. and i agree to go 6 inch
    how are your cvs not hurt at 4 inches?
  6. Jan 4, 2010 at 5:11 PM
    KMN-BLU
    Destin, Fl
    well I should have clarified with "not to bad". Of course it affects the angles but it isnt extreme at all. Not enough that I am worried about it. If I do go back and add the Fabtech 6" on top of what i have, the drop bracket should put them back near perfect im thinking. I want to add that and now 35s or bigger to achieve a 9-10" lift overall. I just hate the thought of cutting that crossmember.
  7. Jan 4, 2010 at 5:12 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I think the CV's are damn near flat on the RCD.
  8. Jan 4, 2010 at 5:17 PM
    KMN-BLU
    Destin, Fl
    Thats because it is a drop bracket lift and still ONLY 4.5" You will actually lose ground clearance with that type of lift albeit maybe only an inch or two so the CVs should stay flat. Thats what a drop bracket kit does.
  9. Jan 4, 2010 at 5:22 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'd go with a Fabtech if you're going the full 6'', otherwise I'd go with the RCD.
  10. Jan 4, 2010 at 5:26 PM
    KMN-BLU
    Destin, Fl
    I have to agree with that statement as far as 6" goes.
  11. Jan 4, 2010 at 5:40 PM
    silvertaco82
    Bozeman, MT
    thanks for the help! i know the pro comp is cheaper but i dont have the money for a set of 35s plus im not sure if i want to go that high. would love to get the rcd 4.5 but its so expensive. I know im kind of changing up my thread but you think i should bet a new rear bumper and just hold off on the lift? i do have a big dent in my stock bumper(thanks to my dad).
  12. Jan 4, 2010 at 5:42 PM
    KMN-BLU
    Destin, Fl
    armortech makes a badass rear bumper. Kevin can customize it however you want and at a fair price.
  13. Jan 4, 2010 at 5:48 PM
    07speedwayblue
    07speedwayblue Well-Known Member
    michael
    nineveh, Indiana
    07tacoma sport 4x4 doublecab
    Jason Rage lid, husky floorliners, Procomp 6" stage 1 lift , bilstein 5100 upfront, 33x12.50r17 MT ATZ tires MT 17x9 Classic Locks,stainless steel brake lines,N-Fab ss nerf bars,smittybuilt grille saver, Amp bed extender,Mbrp cool dual t409 exhaust. KCHiLites Daylighter Driving Lights 6", Pioneer AVH-P4300DVD, HD Tunner, Rear Camera, Focal K2 Power 6.5" Component Speakers Front/Back, Infinity Kappa Four and Kappa One Amps, Infinity Kappa 10" DVC Subs,PowerStop Drilled/Slotted Rotors ,PowerStop Heavy Duty Towing Brake Pads, Blue Painted calipers.
    I went with the procomp stage one, it`s not installed yet, but I decided to go with the procomp , because I want to run the Icon 6'-7" coilovers upfront.
  14. Jan 4, 2010 at 6:25 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Ya, I know that. Just saying the CV angles arent bad at all.
  15. Jan 4, 2010 at 6:56 PM
    dwntwnall4u
    dwntwnall4u Well-Known Member
    Kevin
    san diego
    2013 4x4 Dbl cab Auto
    You should be happy with the Pro Comp 6". I've had no issues.
  16. Jan 4, 2010 at 7:55 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    Remember that you also have to think about the wear and tear that the 6" lift will cause to the steering components. The RCD has lighter spidles compared to fabtech. RCD's are 35lbs and fabtech's are 50lbs. Add this along with a 35" tire and the weight will make your components wear quicker unless you modify them. RCD will clear 33" without any rubbing or trimming. It all depends on how you want your truck. Good luck!
  17. Jan 4, 2010 at 8:30 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    how do you have camburg 4" spindles with a 4x4?
  18. Jan 4, 2010 at 8:34 PM
    ktmrider
    Junk
    wait who has spindles and 4x4:eek::eek::eek:
  19. Jan 4, 2010 at 10:44 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Can't happen. The spindles are too big and do not provide enough clearance for the front driveshafts. In fact I think the new spindles block em completely.
  20. Jan 5, 2010 at 4:33 AM
    KMN-BLU
    Destin, Fl
    m not exactly sure who you are talking to but I certainly didnt say I had spindles. I have a Camburg coil over system that is adjustable beyond 4" if needed.
    Not sure where you read that at.
