RCD 4.5" or Pro comp 6"(basic kit)
Discussion in 'Suspension' started by silvertaco82, Jan 4, 2010.
RCD or Pro Comp
  1. RCD 4.5"
    52.6%
  2. Pro Comp 6"
    40.5%
  3. other(please post)
    6.8%
  1. Jan 5, 2010 at 8:30 AM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    They were talking to Jtaco386
  2. Jan 6, 2010 at 5:26 PM
    silvertaco82
    silvertaco82 [OP] No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    you guys heard anything about the tuff country 6" lift? fount it for 1400
  3. Jan 6, 2010 at 5:37 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    i believe its a coil spacer and then a body lift. stay away from it
    well i just checked and they have one 6" kit listed above. they also have a db coilover kit. dont know anything about them or have any experience with them.
  4. Jan 7, 2010 at 5:19 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    I am unaware of there 6" lift package. However I used Tuff Country 3" lift on my Jeep Wrangler and it screwed that vehicle up so bad I ended up getting rid of it. The shop that installed it could not figure out the problems and TC customer service basically told them to go away.
    The Jeep pulled so hard to the right after install it would throw you off the road. No matter how many alignments they did or adjustments to sway bars it still pulled to the right.
    I got rid of it and now own a tacoma. Maybe a blessing in disguise.
  5. Jan 7, 2010 at 6:38 PM
    05TRD4WD
    05TRD4WD Well-Known Member
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    ; 17 x 9 xd revolvers wrapped in 295/70-R17, volant cold air intake, Gibson exhaust, BHLM, Yellow fog covers, access rollup tonneau, kenwood dnx-9960, all jl audio, jl stealth box, 900/5 amp, Fab Tech 6" lift
    yea i have the fabtech and it rides very good and the cv angle is almost better than stock. but the fabtech drops the front diff down farther than the procmp
  6. Jan 10, 2010 at 3:52 PM
    silvertaco82
    Bozeman, MT
    alright well if i do get a six inch lift it will be the procomp basic kit. I am kinda having second thoughts on getting six inch though. If I did go six inch lift i would keep my same tires. Should i just get the toytec ultimate and a bumper or something like that? just want to know what you guys think
  7. Jan 10, 2010 at 7:42 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    If you dont have any lift right now and want to keep the same tires, then dont go 6", it will look retarded. Are you wanting 3" out of the toytec? That setup sounds good
  8. Jan 10, 2010 at 7:50 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    isn't it the other way around?:confused:
  9. Jan 10, 2010 at 8:41 PM
    HK702
    HK702 [url=http://www.tacomaworld.com/gal
    Jer
    Las Vegas
    Toyota Tacoma 4x4 TRD Sport v6 SR5
    6 in stage 1 pro comp lift, pro comp trac bars, black 17x9.5 moto metal rims 285/70/17 BFG A/T alpine deck and amps JL audio subs and mid highs n-fab nerf bars limo tint
    pro comp!!!!!
  10. Jan 11, 2010 at 11:51 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The RCD lift kit uses New Bilstein 5100 shocks that are much longer, and designed to go with the Lift kit. Instead of a large spacer and just using your factory shocks, like a lot of the other kits. So you get the lift and better perfomance as well. Also top quality design and parts with RCD.
  11. Jan 11, 2010 at 3:08 PM
    silvertaco82
    Bozeman, MT
    I already have 33s with 17" rims and spacer lift. I think that would be fine with the 33s, but im thinking about getting the toyec ultimate lift for a better ride and performance on and offroad. Anyway I could get to around 4" with toytec ultimate?
  12. Jan 11, 2010 at 3:10 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    no you can go over 3 inches with a non drop bracket lift. and even with three inches you would probably need new upper control arms, but you could go with the rcd to get the 4 inches :)
  13. Jan 11, 2010 at 3:17 PM
    silvertaco82
    Bozeman, MT
    ha yeah and double the price along with it
  14. Jan 12, 2010 at 6:16 PM
    silvertaco82
    Bozeman, MT
    alright im set on the 3" ultimate toytec lift but I don't need to buy the whole kit do I? just coilovers since I already have the aal?
  15. Jan 12, 2010 at 9:12 PM
    #35
    jr114
    Jon
    SoCal
    Truck
    coilovers and if you want rear shocks and maybe if you can ucas to help out with alignment
  16. Jan 13, 2010 at 1:28 PM
    #36
    silvertaco82
    Bozeman, MT
    thanks yeah ill definately get ucas and i have bilsteins in rear probably upgrade to 5100s. would I be better off just getting the whole ultimate kit?
  17. Jan 13, 2010 at 3:59 PM
    #37
    jr114
    Jon
    SoCal
    Truck
    if you can afford it and dont have an aal already id say ya go for it. itll take care of everything front and rear and then you wont have to worry about suspension components other than the ucas.
    just read that you do have the aal. check pricing on the whole kit, and on the front and rears together see what it comes out to. by the way what size aal is it? 1.5" and i think you should be good.
  18. Jan 13, 2010 at 4:55 PM
    #38
    Smoken_Bud_671
    Smoken_Bud_671 Well-Known Member
    GU 671
    Shining Beast
    Flowmaster exhuast K&N Intake Filter
    If your going to get bigger tires, definitely go for the Pro Comp 6" lift.
    I have no regrets on the time & money spent on this Bad Boy - Killer Stance!!
  19. Jan 15, 2010 at 8:05 PM
    #39
    silvertaco82
    Bozeman, MT
    its the spacer lift so im pretty sure its a full 2" right?
  20. Jan 15, 2010 at 11:33 PM
    #40
    jr114
    Jon
    SoCal
    Truck
    Ya should be good. Let us know what you wind up doing. Good luck
