RCD 4.5 overall height? And will my stock 16" TRD rims fit with spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYsport23, Mar 23, 2015.
  1. Mar 23, 2015 at 2:02 AM
    TOYsport23
    TOYsport23 [OP] Member
    Hawaii
    20134x4Taco & 20084x4Taco TRD Off-Road
    3" icons stage 3 vs Rcd 4.5 and after reading for the pass week looks like I'm leaning towards rcd lift for my 2013 Tacoma TRD 4x4. But I got a few questions...
    If i install the rcd 4.5 do anyone know what the overall height be from ground to top of cab? And will I fit in 6'6" parking structure?
    Also do anyone know if I can still run my stocks 16" TRD rims and or 17" SPORTS rims? Any pictures out there? Can't deside what rims and tires I want so was planing on running my stocks.
    I have read that rcd lift reuses the stock TRD springs! But do anyone use something else? Maybe some ome or eibach?
    Trucks a daily driver but do go camping and mud trails also use the truck for construction so I do load the bed a lot so need to know what leafs packs would be best for that as well.
  2. Mar 23, 2015 at 2:19 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    The height in front on the rcd kit is 5" front and 4" rear. No you can't run your stock 16 " wheels with this kit. Stock 17's might be able to be run with addition with wheel spacers. Yes the rcd re uses the stock front springs and yes you could add eciach or ome springs for additional lift but you shouldn't go over 1.5 or 2" additional lift. On the rear spring you can get some custom alcans or run expos or dakars with a small block in the rear.
    You might want to check out this thread.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/98012-rcd-club-how-many.html
  3. Mar 23, 2015 at 7:52 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Get the Icon if you plan of going off-roading.
  4. Mar 25, 2015 at 1:38 AM
    TOYsport23
    Hawaii
    Thanks still haven't pick between the two but if post picture for sure.
